603,358 active members*
3,903 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Aquarium air pump for removing chips?
Results 1 to 10 of 10
    Jan 2007
    16
    Is anyone using a aquarium air pump as an alternative to a air compressor for removing chips?
    I have a Dremel tool and cut mostly acrylic, plastics, and wood. I don't want to buy a full air compressor.
    If so, what size are you using? Rated in Litre/second. Watts?
    Mar 2005
    1673
    That’s a novel idea. I use them but in my aquarium and would think to work as you plan it’s going to have to be a real beast of a pump.
    Have you thought about diverting the air from your Dremel to clear chips would probably be as effective as using a aquarium pump imho?
    John
    Jun 2005
    1436
    How about using a domestic vacuum cleaner modified, such that some of the air from the output end is blowing onto the cutting area ?
    Get the balance right so that you dont get any heat build up.
    John
    It's like doing jigsaw puzzles in the dark.
    Enjoy today's problems, for tomorrow's may be worse.
    Jan 2007
    16
    Quote Originally Posted by Oldmanandhistoy View Post
    What size beast will be necessary? I was hoping a small, inexpensive air pump would work. I have never tested an aquarium air pump.
    John
    Haven't tried that but I don't think there is enough air flow to blow the chips out.
    Jan 2007
    16
    Quote Originally Posted by greybeard View Post
    John
    I might try this as I need to get a shopvac soon. May rig up some system to have vacuum and recycle the vacuum output for air blow.
    Quote Originally Posted by icupeter View Post
    That's what I have done, and it works very well. If you get all your hoses lined up right, you end up blowing the chips directly into the vacuum inlet, and everything stays remarkably clean.
    Jun 2007
    44
    could the same system be used for vacuum clampdown and chip blowing?
    i dont know sqat!!! will be asking dumb questions
    Oct 2006
    735
    Scroll saw people have used aquarium pumps to blow the chip path after they use their scroll saws so long the bellows pump with the saw ends up failing..hehe That only happens to the very serious scroll sawers though.
    b.
    Jun 2005
    1436
    Quote Originally Posted by shashank ayyar View Post
    No. As soon as you close the air suply to the vacuum hold down you won't have any air for the chip clearance.
    Why not get a second vac cleaner ?
    John
    Nov 2005
    1468
    I started off using a domestic vacuum cleaner and found that the bag got really clogged up with coolant (WD40)- I went through quite a few of them then bought one of these Dyson type vacuum cleaners (no bag). That seemed to work ok. But then I went to a Venturi extraction system that uses compressed air at the front of the extraction pipe to create a vecuum. It works well when set up ok- chips fly out the back of the pipe and get collected in a big sack, but then again, my chips are very light- they float about the lab in big long ssilvery strings like tinsel- looks good at Xmas
    I love deadlines- I like the whooshing sound they make as they fly by.
  1. Removing a Gecko
    By sploo in forum Gecko Drives
    Last Post: 12-11-2006, 11:51 PM
  2. Removing nut off ballscrew, I've never seen anything like it
    By geohot in forum Linear and Rotary Motion
    Last Post: 12-24-2005, 04:53 AM
  3. How to removing a pulley from a motor ??
    By RotorRouter in forum CNC Machine Related Electronics
    Last Post: 11-13-2005, 02:32 AM
  4. Removing the armature ?
    By Ken_Shea in forum Servo Drives
    Last Post: 10-10-2005, 08:40 PM
  5. Cook your chips to make more chips :)
    By ToMMY2ooo in forum Bending, Forging, Extrusion...
    Last Post: 09-07-2004, 07:38 PM
