Just installed a Proma thc sd. I'm using mach3. Issue I am having is the thc moves the z axis as needed but mach3 does not see the z axis moving. So any adjustments it makes, when starting a new cut it can dive into the metal and drag it. I have Thc turned on in inputs and mill options. Even have it turned on on the home screen. Also won't turn on the indicators on the diag screen forntorch up and down. Any ideas?
