I've been looking all over for a good description on how to wire the cnc port on the everlast pp80s, the proma thc, to the smoothstepper but cant seem to find much info. if anyone has done this, or is good with electronics id greatly appreciate the help.
everlast 80s cnc pinout- page 25- http://www.everlastgenerators.com/si...20S%202016.pdf
proma thc- http://proma-elektronika.com/download/PDF/thc150_en.pdf
the THC has 4 outputs- up, arc ok, down, common. the up and down go to the smoothstepper and config those inputs in mach3. the common is a ground from the smoothstepper. is the arc ok configured as an input too inside mach3?
the cnc port on the plasma also has 2 pins that are "ok to move" which is also arc ok. do I connect these to mach3? leave them out?
I'm also going with the raw voltage output from the plasma to the THC. which the manual says is pins 5-7. doesn't say which is pos or neg?
this is my first plasma build, if you cant tell lol I'm just trying to wrap my head around the plasma end of it. everything else is done, was planning to wire this last "little" bit and put fire to it tomorrow. until all this confused the hell out of me lol.
any help is greatly appreciated. ive seen the same configuration of parts on youtube working. so I know it can be done, its just figuring it all out.
