586,072 active members*
4,714 visitors online*
    Jul 2006
    16
    multi depths in 1 programm
    hello, every 1. i am using mach 3 licenced version & want to gine multi depths in same programm. is that possible? how
    Apr 2003
    550
    Quote Originally Posted by ajitsingh View Post
    I am not sure what you are asking all you have to do is change the Z value and it will go to that depth. It goes to any depth you tell it to....
    If you want to do true 3D then you need a cad and a cam to generate the proper tool path.
    If you just want to cut one chain at one depth and the next chain at another depth you just need the chains on seperate layers and set the depth for each chain,,
    I strongly sugust that you go watch all the Lazt Cam videos on the Mach website as Art shows how to do this pretty clearly.
    Garry
    Jul 2006
    16
    multi depths
    hello, thanks for reply,
    wat i need is, i want to cut the same chain with different depths. rather giving depth every time.(example- i want to cut depth say 5mm & to cut that in 5 times depth).
    hoping u got it.
    thanks & hoping for favourable reply
    ajit
  1. Incremental Z Depths In Drilling
    By Litnin in forum Mastercam
    Last Post: 03-01-2012, 04:28 PM
  2. Z-finish Depths
    By jamesr in forum Surfcam
    Last Post: 12-20-2006, 07:07 PM
  3. Multi-motors
    By Tsukuyomi in forum Stepper Motors / Drives
    Last Post: 05-03-2006, 02:45 AM
  4. Cutting at multiple depths.. looping ??
    By esmiller in forum Mach Software (ArtSoft software)
    Last Post: 01-31-2006, 12:48 PM
  5. Depths of cut on a lathe
    By M@T in forum Uncategorised CAM Discussion
    Last Post: 01-30-2004, 04:40 PM
