586,103 active members*
3,468 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Zero pierce time in Sheetcam?
    Feb 2017
    Maybe I'm missing something here but setting pierce time to 0 "zero" still leaves a short pause before the torch starts to travel. Is it possible to have no pause either before of after the cut? Just using the torch to etch.
    MM
    Oct 2010
    156
    Re: Zero pierce time in Sheetcam?
    If there is code to wait for the ARC-OK signal, this may add the time you are seeing.
    May 2012
    23
    Not sure if you're using Mach, but could it not be your spindle on delay if you do? In Mach go to: Config > Ports and Pins > Spindle Setup > General Parameters. and set all to 0
  1. Replies: 0
    Last Post: 11-20-2013, 08:34 AM
  2. Mach3 ignoring preheat time from sheetcam
    By Donn in forum Mach Software (ArtSoft software)
    Last Post: 08-18-2012, 03:52 PM
  3. Sheetcam Wiggle pierce Settings.
    By rescueweasel in forum SheetCam
    Last Post: 10-12-2010, 06:13 AM
  4. Pierce Delay even when set to 0?
    By Wolfesmetalfab in forum Mach Plasma / Laser
    Last Post: 02-03-2009, 05:00 AM
