586,112 active members*
3,009 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > I desperately need some help setting up a viper250 servo driver
    May 2005
    13
    I just got the board and I'm in way over my head. I have the manual for the Viper 200 downloaded from the website but I'm to dumb to figure it out. My first question is were should I put the jumpers? The manual has diagram showing 5 pairs of jumper pins my board only has 3 pair.
    Is there a way to load the settings from one of the other Viper 200 boards on the machine, which seem to be working?
    Any help would be greatly appreciated.
    Feb 2008
    42
    Re: I desperately need some help setting up a viper250 servo driver
    Quote Originally Posted by skypilot View Post
    I know this is an old posting, but certainly a valid question.
    I too own a 250 which I will be dropping into a retrofit. Here is Larry's response to the question:
    The bottom 2 are step multiplier same as V200. the top one isn't used.
    The drive only has 1 bank.( not 3 like older V200F)
    Just an FYI for those who will be purchasing this product in the future.
    Mark
    Need a Supermax YCM-40 Mill manual? Download the PDF here (replace _ with .):
    http://www.istonline.ca/download/supermax-ycm-40.pdf
  1. Yaskawa Servo driver CPCR-MR01C Driver problem
    By pvpatel in forum Benchtop Machines
    Last Post: 04-04-2016, 09:25 AM
  2. stepper driver using h-bridge to analog servo driver
    By aztec in forum Servo Motors / Drives
    Last Post: 02-07-2016, 06:24 PM
  3. Replies: 6
    Last Post: 11-20-2015, 07:11 PM
  4. Replies: 0
    Last Post: 02-07-2014, 01:29 AM
  5. Servo motor specs. and driver setting questions.
    By southernexplore in forum Servo Motors / Drives
    Last Post: 08-04-2006, 01:21 PM
