603,320 active members*
2,670 visitors online*
    Sep 2005
    280
    Fanuc 31i model A
    Cant use measure on G55-G59 says its protected? must be a parameter that I dont see in the book. also is there a way to get rid of it asking me if its ok after I make a offset with the + (incremental) pain in the a*$% thanks
    Re: Fanuc 31i model A
    Press the Offset/Setting function button. Press the far right soft key under the monitor till you see GUARD. You will find your settings there.
    2932
    Quote Originally Posted by positiverake View Post
    IIRC, you have to have the WCS (G54 - G59) active to use the MEASURE function. Try MDI G55; INSERT Cycle Start, then see if you can measure G55.
    Sep 2005
    280
    Thank you both! you were spot on. thanks
  1. Replies: 1
    Last Post: 04-14-2014, 07:41 PM
  2. Fanuc 15M Model B
    By bill4807 in forum Fanuc
    Last Post: 01-16-2014, 12:56 AM
  3. fanuc 0M MODEL B
    By zavateandu in forum Fanuc
    Last Post: 02-19-2010, 04:59 PM
  4. fanuc ot model c
    By bryanh in forum Fanuc
    Last Post: 02-19-2010, 02:38 PM
  5. fanuc 31i - model A5
    By anilam in forum Fanuc
    Last Post: 02-15-2010, 02:22 PM
