586,102 active members*
2,620 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Can't remember how to synchronize sub with main
    Jan 2016
    7
    I have a part that I'm tapping a 6/32 threaded thru hole on the main spindle. Running a Citizen L20 VIII. Using G84.
    I want to go back in the hole with a tap on the sub side. For the life of me I can't recall how to do this. I'm pretty certain it's G114 but I'm sure I'm missing something else?
    Sep 2011
    261
    Re: Can't remember how to synchronize sub with main
    You'd definitely need to use a phased pickoff. Once you do a phased pickoff, you will have to play around with the R value until the threads line up on the sub.
    G114.1G114.1- SPINDLE SYNCHRONIZE. Used to exactly lock the P.O
    and the main spindle. G96 can be used also. We can also phase shift
    so we can pick up odd shapes while the spindle is running or orient fratures from main to sub
    G114.1 H1 D-2 R0 (if 'R' is used then 'M77' is needed)
    - H1= Commanding spindle 1 for S1 main spindle
    - D-2= Following spindle 2 for S2 PO spindle - Rotation like m24
    - R0 = Degrees of rotation - controls orientation of sub relative to main
    Example
    T100
    G50W-.094S50
    G0X1.1Z4
    M97M95
    M3S1=1000M24S2=1000
    G114.1 H1 D-2 (not using G814 or M77 to save time)
    G96 M3 S200(MAIN SPL COMES ON AND PO SPL AL
    G650 (PO SPL COMES OVER THE PA
    !L1 (WAIT PO SPL CH
    G1X-.05F.0
    X-.1F.003
    G50W.094
    G97M
    G113
    G600
    Or you could use G814. From the manual:
    G814-Same as G114.1 but you don't need all the codes on the
    command line. You can use the R command for phase shifting
    Citizen added this macro just to make it easier to use spindle
    sync. See G114.1 and G113. You may save time by not using G8
    G814 even with no 'R' argument will internally use 'R0' and this
    Example:
    G814 R10. same as G114.1 H1 D-2 R10.
    G814 (no R) same as G114.1 H1 D-2 R0
    Good luck!
    CNC Product Manager / Training Consultant
    304
    Quote Originally Posted by MCImes View Post
    Example
    T100
    G50W-.094S50
    G0X1.1Z4
    M97M95
    M3S1=1000M24S2=1000
    !L1 (WAIT PO SPL CH
    G1X-.05F.0
    X-.1F.003
    G50W.094
    G97M
    G113
    G600
    Example:
    Good luck!
    You MUST add the line M77 to "Phase" the two spindles.
    The G114,1 H1D-2 MATCHES the spindle RPMs and direction.
    Adding the R0 (or R ##)
    will correct the ZERO position while matching the RPMs
    ONLY IF YOU ADD THE COMMAND TO PHASE ADJUST!! (M77)
    The line following the G114.1 or G814 must be "M77"
    Now you will have the thread start position consistant and will be able to chase the thread once you get the R## correct to match.
  1. how to synchronize a BLDC and a stepper motor?
    By acannell in forum Stepper Motors / Drives
    Last Post: 11-12-2013, 06:02 AM
  2. synchronize a stepper with lathe spindle?
    By jbrookes in forum Stepper Motors / Drives
    Last Post: 12-02-2012, 03:02 PM
  3. Synchronize Spindles
    By daewooevc in forum Okuma
    Last Post: 12-28-2011, 03:25 AM
  4. synchronize two motor in one axis
    By ferdi_mcrohl in forum LinuxCNC (formerly EMC2)
    Last Post: 02-26-2010, 08:47 AM
  5. How do I synchronize 4th axis speed with X,Y,Z?
    By buscht in forum DIY CNC Router Table Machines
    Last Post: 08-02-2005, 02:42 PM
