Re: Help mounting motor on Techno DaVinci
Alex,
check out the Z axis on that machine - the Y axis mount is identical to it.
One thing to watch for - if the machine complains it's at the end of travel when you start up and/or it won't home properly, flip the small black connector that plugs into the coupling box's circuit board around 180 degrees. Nothing bad happens if it's backwards - it just won't see the home switch.
Eric
Eric Feldman - Design Engineer, Programmer
Armor CNC - http://www.armorcnc.com Support hours: 7am thru 10pm EST, 7 days a week
