586,973 active members*
2,951 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Forward reverse step motor advice
    Mar 2017
    Question Forward reverse step motor advice
    Hello,
    I'm looking for advice for a motor that can rotate 90 degrees and then reverse and go back and continue this operation until it is turned off. Probably a stepper motor but need advice on what kind.
    Needs to be connected to a battery supply so will also need a ac/dc convertor
    Needs to carry between 4-7ounces
    I'm completely new to this so specifics will help with this project.
    Thank you for any advice,
    Matthew
    Dec 2013
    5714
    Re: Forward reverse step motor advice
    If the system is 12V then use a windshield wiper motor from a vehicle and a mechanical bellcrank arrangement. In fact, just grab the works from a windshield wiper system, they move through an arc of 90°
    Jul 2016
    660
    Nice simple idea you got there sir hehe, it`s a hell of a lot faster constructing a project using your idea than building it from scratch, I mean like acquire an arduino or raspberrypi modules, programming a looping script on the PWM outputs (GPIO) acquire a stepper motor kit, wiring them all up to do just a 90 degree work on the stepper motor. I did tried these projects a few months ago but a more sophisticated one, a smartphone controlled mounting device with a 720p bulit-in camera, auto aim on target meaning it follows a moving object whenever you locked it to them, you can see your target in your smart phone then trigger the attachment remotely by just double tapping the screen or the volume up button on the smartphone.
    http://www.cnczone.com/forums/attach...d=355634&stc=1
    http://www.cnczone.com/forums/attach...d=355636&stc=1
    Just think of it that it`s only an airsoft gun, not a deadly weapon, not the TCM 22 rock island pistol hehe
    Mar 2017
    Good idea but looking for a lot less weight and smaller batteries. A, C or D batteries. If I'm able to get all of the bugs worked out eventually want to sell the device so needs to be as small and compact to ship
    Dec 2013
    5714
    Quote Originally Posted by Birdz View Post
    Without knowing all of the design parameters it's pretty hard to offer any meaningful advice. There are several ways of doing what you want, and the least cost might be a purely mechanical system. There are some very tiny gear motors available, and many will run 1.5 to 3 volts or so. To sweep a 90° arc, all you need is a bellcrank off of a rotating shaft. There is also a type of transmission that rotates a shaft through 90° and repeats (think washing machine transmission). I have seen these in small toys.
    Another option is a small 5V stepper motor and a small driver, that coupled with a PIC chip and a little programming, would do what you want. A simple linear motor would also do the job (think solenoid). The posibilities are almost endless.
  1. Pega357 1 step forward, 999 steps back
    By Oliver_Matthews in forum Fanuc
    Last Post: 03-01-2017, 09:53 AM
  2. Replies: 51
    Last Post: 05-15-2013, 10:23 AM
  3. Replies: 2
    Last Post: 02-21-2013, 07:58 PM
  4. Spindle Forward/Reverse = High/Low change
    By AdyAstley in forum Machines running Mach Software
    Last Post: 06-07-2007, 03:33 AM
  5. Can bad forward/reverse toggle cause motor not to spin?
    By ZipSnipe in forum CNC Machine Related Electronics
    Last Post: 06-03-2006, 02:45 PM
