586,089 active members*
3,957 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC 21-M PMC PARAMETERS FOR EXCEL VERTICAL MILL
Results 1 to 7 of 7
    Dec 2012
    4
    Hello, so I have lost pmc parameters on a 1997 Excel PMC-10-T24 vertical mill with 21-MB. took out mother board as per Fanuc request for a clean and test because of i/o issues and fanuc said all i needed to back up were nc parameters.
    not true and now I have none of the PMC parameters and Excel has no support as out of business.
    It will run programs just no auto tool change looks like tool data parameters are needed?
    yes i should of researched a little more before tearing it apart! only fanuc we have so not to familiar with it.
    any help would be greatly appreciated!
    May 2009
    106
    Quote Originally Posted by RCD ROG View Post
    Fairly sure I saved all memory from one of these last year.
    I can check monday.
    Where are you located at?
    Dec 2012
    4
    Re: FANUC 21-M PMC PARAMETERS FOR EXCEL VERTICAL MILL
    oh wow that would be awesome! I am located in Nevada City California.
    Dec 2012
    4
    any luck with finding excel parameters?
    Jan 2011
    129
    Any luck in finding these parameters.
    Please share if available.
    Nov 2020
    Did you guys ever get these parameters? I have a similar machine and was hoping i could get a copy of your settings.
    Jan 2010
    merhaba
    excel pmc10t24 dik i?leme merkezi var bende atc tak?m de?i?tirmiyor bunun için parametre gerekli yard?mc? olursan?z sevinirim whatssap +90 506 852 25 91 e-mail [email protected] [email protected]
  1. kiwa excel 510 parameters
    By gbsengineers in forum Fanuc
    Last Post: 12-06-2023, 11:17 PM
  2. Need parameter for Excel PMC-10T24 vertical machining centre
    By ichiryu in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-17-2023, 07:03 PM
  3. Need Parameters for an EXCEL CMT-350T20
    By Kvlach in forum Maintenance DIY Discussion
    Last Post: 12-11-2020, 10:37 PM
  4. Excel 810 VMC Parameters Fanuc O-M
    By pvougi in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-15-2020, 08:48 AM
  5. Kuraki vertical mill fanuc 15 M control
    By edr4867 in forum Fanuc
    Last Post: 02-20-2016, 07:23 PM
