586,076 active members*
3,822 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need Help with 5 Axis Bob / Mach3 / Huanyang Spindle Setup
Results 1 to 11 of 11
    Mar 2017
    16
    Hi All,
    I have a Smartsain 5 axis BOB and Mach3 and a Huanyang Spindle.
    I would like to wire my BOB so it can do the following functions
    1) turn spindle on / off
    2) revers / forward spindle
    3) control spindle speed.
    Supposedly with the correct wiring this can all work thru Mach3 and my Break out Board.
    Can someone please help me out with a wiring diagram.
    Thanks Steven
    Re: Need Help with 5 Axis Bob / Mach3 / Huanyang Spindle Setup
    1 & 2 are the same. The forward or reverse commands start the spindle.
    Unfortunately, you can't do both with this board, as there's only one relay. See this image.
    http://www.omc-stepperonline.com/ima...d-st-v2_01.jpg
    The terminals marked "Spindle On/Off Control Interface" are controlled by the relay, and go to the FWD terminal on the VFD.
    The terminals marked 0-10V spindle speed go to the VI and DCM terminals. Look at the bottom of the board, for terminal information.
    Assign Pin #1 in Mach3 to the PWM signal.
    Dec 2014
    103
    I have the same set up and can only use it to go one way. My output was only 5 volts so I bought a pwm board to use the 10 volt from the vfd and got it to work that way but if you read the book that comes with the vfd you can set it for 0-5 I did post a short youtube video It may not be the way the pros would have wired it but it has worked for me
    Mar 2017
    16
    Ok, maybe I am a little dense. I get that the 0 - 10V go to VI and DCM, does it matter which one goes to which ??
    and
    there are two place to wire to the spindle on/off. Do I just wire one to the FWD ??
    Thanks Steven
    I made a mistake. Look at the back of your board. The one labeled ground goes to ACM, the one that says 0-10V PWM goes to VI.
    One to FWD, and the other to DCM
    Mar 2017
    16
    Ok, All wired up. BUTTTT it does not work right. I hear a click when I push the spindle toggle in Mach3 but I still have to hit the "run" button on the VFC. Then it only goes to a freqency of 100. 400 is the highest.
    I did set up what I thought was correct in Mach3. I set up the Pully . I set up the output to #1.
    I even checked the VFC and the pin connector is on "VI"
    any ideas ????
    What do you have PD001 and PD002 set to?
    And where is the jumper (J1) next to the screw terminals?
    You probably need to go through all of the VFD parameters and set them up correctly.
    Mar 2017
    16
    PD001 and PD002 are set to "0"
    PD003 = 100
    Yes the J1 is set next to the terminal.
    Thanks Steven
    Dec 2014
    103
    pd 1 and pd2 need to be set to 1
    Mar 2017
    16
    Quote Originally Posted by minicncuser View Post
    You are the man !!!
    Works great.
    Mar 2017
    4
    Hello, I use the same board with LinuxCNC and my problem is that at the speed 0 the output is 10V and at full speed the output is 0V. It is supposed to be opposite...
    How is it in Mach3 ? Thank you
  1. dyna 4000 mach3 spindle setup
    By lemur in forum DynaCNC
    Last Post: 01-10-2017, 02:22 AM
  2. Mach3 setup spindle motor
    By christensen in forum Mach Software (ArtSoft software)
    Last Post: 08-24-2016, 10:40 PM
  3. Mach3 Z axis setup.
    By Rare-Models in forum Avid CNC
    Last Post: 04-28-2016, 03:03 PM
  4. 4th axis setup G540 and Mach3
    By HakBot in forum Gecko Drives
    Last Post: 10-19-2011, 01:16 AM
  5. Can i use/setup a servo motor as spindle in mach3
    By schwinndk in forum Mach Software (ArtSoft software)
    Last Post: 03-06-2010, 07:00 PM
