603,870 active members*
7,981 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Mori Seiki MV40 ceramic spindle liner
    Mar 2014
    What year did Mori Seiki start using, and with what models the ceramic spindle liner in their machining centers..also when did they stop? Also has anyone had success in repairing or rebuilding them especially with a steel insert? Thanks!
    Feb 2009
    6028
    Re: Mori Seiki MV40 ceramic spindle liner
    Mv40 was the most common. Stopped around 94, but no hard cutoff date im aware of. I personally have had several rebuilt at CM with steel liners. Unfortunately not a easy DIY as i believe they strip the spindle down and sweat in the new insert, re grind the bearing area, new bearings then grind the taper in for as close as they can get to zero run out. Last time i had it done was around 8K.
    Sent from my SM-T813 using Tapatalk
    Mar 2014
    Thanks! Great information to know. Wow, expensive...I thought a new spindle was about 10K, but you end up with the same problem again a few years down the road, not so with a steel liner. Thanks again!
    May 2014
    20
    Great to finally find someone who uses a MV-40 as well. our ceramic spindle liners is chipped and cracked. is there no replacement for this part then? as in a bolt in replaceable part?
    value any info i can get on this.
  1. MORI SEIKI MV40
    By simke55 in forum Mori Seiki Mills
    Last Post: 04-12-2017, 07:50 PM
  2. Mori Seiki MV40 with Fanuc OM-C
    By rai in forum Mori Seiki Mills
    Last Post: 11-03-2015, 04:30 PM
  3. 1987 Mori Seiki MV40 circuit diagrams and manuals Yasnac MX3
    By ross33912 in forum Mori Seiki Mills
    Last Post: 01-01-2015, 09:13 AM
  4. Ladder Diagram for Mori Seiki MV40/Fanuc 6M-B
    By Randy K in forum Mori Seiki Mills
    Last Post: 03-06-2012, 11:21 AM
  5. Mori mv40 24v troubleshoot
    By toolwrite in forum Mori Seiki Mills
    Last Post: 03-06-2010, 12:31 AM
