586,102 active members*
2,620 visitors online*
Results 1 to 7 of 7
    Apr 2017
    77
    VCARVE and Mach3
    Hi
    When i create my object to mill in vcarve and set the home point to the bottom left and the build size 200mm x 200mm it all appears fine in vcarve but when i import the gcode into mach3 the text moves from the center to the top of the build.
    Anyone else had this and can help me fix the issue?
    Mach3 by foxinola | Photobucket
    Re: VCARVE and Mach3
    Where it appears on the screen does not necessarily mean it's in a different location.
    As a test, create a toolpath of a square thats about 180x180, offset by 10mm, where you can easily check the coordinates.
    Or, upload your V Carve file and g-code.
    Apr 2017
    77
    Hi
    It cuts in that location that is displayed.
    https://www.dropbox.com/s/m5fsdf3diz...opbox.zip?dl=0
    Jul 2016
    660
    The code is perfect on my side, the issue on this is the homing position during the auto CAM process, I think you need to set it to the center as you want it, you accidentally set it to the X0 Y0 before the auto CAM process
    Code:
    ( V-Carve 2 )
    ( File created: Thursday, April 13, 2017 - 05:08 PM)
    ( for Mach2/3 from Vectric )
    ( Material Size)
    ( X= 200.000, Y= 200.000, Z= 10.000)
    (Toolpaths used in this file:)
    (V-Carve 1)
    (Tools used in this file: )
    (1 = V-Bit {90 deg 1.25"})
    N100G00G21G17G90G40G49G80
    N110G71G91.1
    N120T1M06
    N130 (V-Bit {90 deg 1.25"})
    N140G00G43Z20.000H1
    N150S12000M03
    N160(Toolpath:- V-Carve 1)
    N170()
    N180G94
    N190X0.000Y0.000F2540.0
    N200G00X-81.489Y19.963Z6.000
    N210G1Z-3.171F762.0
    N220G1X-81.150Y20.120Z-3.014F2540.0
    N230G1X-80.748Y20.277Z-2.857
    N240G1X-80.224Y20.435Z-2.699
    N250G1X-79.854Y20.513Z-2.621
    N260G1X-79.592Y20.553Z-2.581
    N270G1X-78.960Y20.592Z-2.542
    N280G1X-69.831Y20.592Z-2.542
    N290G1X-68.589Y20.579Z-2.544
    N300G1X-67.375Y20.539Z-2.550
    N310G1X-66.234Y20.472Z-2.559
    N320G1X-65.164Y20.376Z-2.571
    N330G1X-63.991Y20.220Z-2.592
    N340G1X-63.212Y20.078Z-2.604
    N350G1X-62.318Y19.857Z-2.617
    N360G1X-61.519Y19.603Z-2.637
    N370G1X-61.005Y19.405Z-2.655
    N380G1X-60.498Y19.186Z-2.676
    N390G1X-59.907Y18.891Z-2.702
    N400G1X-59.145Y18.445Z-2.730
    N410G1X-58.579Y18.063Z-2.751
    N420G1X-58.129Y17.724Z-2.767
    N430G1X-57.354Y17.055Z-2.790
    N440G1X-56.634Y16.336Z-2.813
    N450G1X-56.027Y15.643Z-2.829
    N460G1X-55.402Y14.830Z-2.840
    N470G1X-54.934Y14.140Z-2.846
    N480G1X-54.408Y13.261Z-2.845
    N490G1X-53.996Y12.459Z-2.849
    N500G1X-53.594Y11.541Z-2.855
    N510G1X-53.234Y10.566Z-2.862
    N520G1X-52.920Y9.542Z-2.874
    N530G1X-52.645Y8.450Z-2.886
    N540G1X-52.493Y7.701Z-2.893
    N550G1X-52.336Y6.796Z-2.906
    N560G1X-52.152Y5.334Z-2.918
    N570G1X-52.071Y4.402Z-2.928
    N580G1X-51.997Y2.781Z-2.934
    N590G1X-51.985Y1.824Z-2.939
    N600G1X-52.005Y0.586Z-2.938
    N610G1X-52.068Y-0.664Z-2.934
    N620G1X-52.173Y-1.876Z-2.928
    N630G1X-52.321Y-3.049Z-2.919
    N640G1X-52.536Y-4.301Z-2.909
    N650G1X-52.752Y-5.279Z-2.893
    N660G1X-53.038Y-6.335Z-2.873
    N670G1X-53.361Y-7.342Z-2.858
    N680G1X-53.767Y-8.422Z-2.848
    N690G1X-54.112Y-9.219Z-2.835
    N700G1X-54.548Y-10.099Z-2.821
    N710G1X-55.048Y-10.976Z-2.806
    N720G1X-55.548Y-11.728Z-2.783
    N730G1X-56.156Y-12.532Z-2.763
    N740G1X-56.713Y-13.177Z-2.744
    N750G1X-57.354Y-13.829Z-2.727
    N760G1X-57.878Y-14.291Z-2.713
    N770G1X-58.555Y-14.805Z-2.701
    N780G1X-59.017Y-15.110Z-2.688
    N790G1X-59.630Y-15.463Z-2.671
    N800G1X-60.431Y-15.858Z-2.652
    N810G1X-60.977Y-16.090Z-2.636
    N820G1X-61.615Y-16.328Z-2.618
    N830G1X-62.346Y-16.562Z-2.599
    N840G1X-63.126Y-16.771Z-2.584
    N850G1X-64.190Y-16.993Z-2.575
    N860G1X-64.930Y-17.113Z-2.568
    N870G1X-65.704Y-17.213Z-2.563
    N880G1X-66.653Y-17.301Z-2.557
    N890G1X-67.649Y-17.362Z-2.552
    N900G1X-69.131Y-17.399Z-2.546
    N910G1X-78.960Y-17.403Z-2.542
    N920G1X-79.592Y-17.364Z-2.581
    N930G1X-79.854Y-17.324Z-2.621
    N940G1X-80.224Y-17.246Z-2.699
    N950G1X-80.748Y-17.088Z-2.857
    N960G1X-81.150Y-16.931Z-3.014
    N970G1X-81.489Y-16.774Z-3.171
    N980G1X-81.650Y-16.214Z-3.011
    N990G1X-81.730Y-15.818Z-2.931
    N1000G1X-81.770Y-15.537Z-2.890
    N1010G1X-81.810Y-14.861Z-2.850
    N1020G1Y18.050
    N1030G1X-81.770Y18.726Z-2.890
    N1040G1X-81.730Y19.007Z-2.931
    N1050G1X-81.650Y19.403Z-3.011
    N1060G1X-81.489Y19.963Z-3.171
    N1070G00Z6.000
    N1080G00Y-16.774
    N1090G1Z-3.171F762.0
    N1100G1X-81.150Y-16.931Z-3.014F2540.0
    N1110G1X-80.748Y-17.088Z-2.857
    N1120G1X-80.224Y-17.246Z-2.699
    N1130G1X-79.854Y-17.324Z-2.621
    N1140G1X-79.592Y-17.364Z-2.581
    N1150G1X-78.960Y-17.403Z-2.542
    N1160G1X-68.695Y-17.394Z-2.546
    N1170G1X-67.345Y-17.346Z-2.556
    N1180G1X-66.508Y-17.290Z-2.559
    N1190G1X-65.609Y-17.201Z-2.563
    N1200G1X-64.694Y-17.078Z-2.568
    N1210G1X-63.820Y-16.923Z-2.575
    N1220G1X-62.809Y-16.691Z-2.593
    N1230G1X-62.166Y-16.509Z-2.605
    N1240G1X-61.495Y-16.286Z-2.621
    N1250G1X-60.803Y-16.019Z-2.639
    N1260G1X-60.135Y-15.720Z-2.657
    N1270G1X-59.433Y-15.356Z-2.678
    N1280G1X-58.876Y-15.019Z-2.691
    N1290G1X-58.290Y-14.614Z-2.704
    N1300G1X-57.735Y-14.172Z-2.717
    N1310G1X-57.216Y-13.696Z-2.729
    N1320G1X-56.546Y-12.993Z-2.751
    N1330G1X-55.999Y-12.334Z-2.766
    N1340G1X-55.400Y-11.516Z-2.792
    N1350G1X-54.940Y-10.795Z-2.808
    N1360G1X-54.475Y-9.961Z-2.824
    N1370G1X-54.051Y-9.087Z-2.838
    N1380G1X-53.667Y-8.173Z-2.848
    N1390G1X-53.316Y-7.210Z-2.860
    N1400G1X-52.953Y-6.043Z-2.882
    N1410G1X-52.720Y-5.150Z-2.895
    N1420G1X-52.491Y-4.062Z-2.909
    N1430G1X-52.305Y-2.935Z-2.920
    N1440G1X-52.162Y-1.770Z-2.928
    N1450G1X-52.049Y-0.372Z-2.938
    N1460G1X-52.001Y0.709Z-2.939
    N1470G1X-51.985Y1.948Z-2.937
    N1480G1X-52.006Y3.138Z-2.936
    N1490G1X-52.085Y4.575Z-2.925
    N1500G1X-52.181Y5.621Z-2.919
    N1510G1X-52.372Y7.017Z-2.901
    N1520G1X-52.539Y7.944Z-2.893
    N1530G1X-52.822Y9.179Z-2.876
    N1540G1X-53.071Y10.060Z-2.867
    N1550G1X-53.409Y11.060Z-2.858
    N1560G1X-53.792Y12.014Z-2.850
    N1570G1X-54.215Y12.898Z-2.848
    N1580G1X-54.727Y13.811Z-2.845
    N1590G1X-55.193Y14.531Z-2.845
    N1600G1X-55.774Y15.328Z-2.834
    N1610G1X-56.466Y16.153Z-2.816
    N1620G1X-56.954Y16.669Z-2.803
    N1630G1X-57.619Y17.295Z-2.783
    N1640G1X-58.222Y17.797Z-2.764
    N1650G1X-58.714Y18.160Z-2.748
    N1660G1X-59.294Y18.540Z-2.727
    N1670G1X-60.114Y18.997Z-2.690
    N1680G1X-60.612Y19.238Z-2.672
    N1690G1X-61.242Y19.502Z-2.650
    N1700G1X-61.970Y19.754Z-2.630
    N1710G1X-62.743Y19.970Z-2.614
    N1720G1X-63.364Y20.110Z-2.602
    N1730G1X-64.284Y20.265Z-2.584
    N1740G1X-65.598Y20.419Z-2.569
    N1750G1X-66.531Y20.493Z-2.558
    N1760G1X-67.547Y20.547Z-2.550
    N1770G1X-68.653Y20.581Z-2.544
    N1780G1X-69.909Y20.592Z-2.542
    N1790G1X-78.960
    N1800G1X-79.592Y20.553Z-2.581
    N1810G1X-79.854Y20.513Z-2.621
    N1820G1X-80.224Y20.435Z-2.699
    N1830G1X-80.748Y20.277Z-2.857
    N1840G1X-81.150Y20.120Z-3.014
    N1850G1X-81.489Y19.963Z-3.171
    N1860G1X-84.660Y23.134Z0.000
    N1870G1X-81.489Y19.963Z-3.171
    N1880G1X-81.650Y19.403Z-3.011
    N1890G1X-81.730Y19.007Z-2.931
    N1900G1X-81.770Y18.726Z-2.890
    N1910G1X-81.810Y18.050Z-2.850
    N1920G1Y-14.861
    N1930G1X-81.770Y-15.537Z-2.890
    N1940G1X-81.730Y-15.818Z-2.931
    N1950G1X-81.650Y-16.214Z-3.011
    N1960G1X-81.489Y-16.774Z-3.171
    N1970G1X-84.660Y-19.945Z0.000
    N1980G1X-81.489Y-16.774Z-3.171
    N1990G00Z6.000
    N2000G00X-15.880Y-3.766
    N2010G1Z-3.373F762.0
    N2020G1X-16.416Y-3.970Z-3.015F2540.0
    N2030G1X-16.735Y-4.091Z-2.835
    N2040G1X-17.133Y-4.242Z-2.656
    N2050G1X-17.649Y-4.409Z-2.489
    N2060G1X-18.014Y-4.493Z-2.405
    N2070G1X-18.272Y-4.535Z-2.363
    N2080G1X-18.896Y-4.576Z-2.321
    N2090G1X-33.500
    N2100G1X-34.082Y-4.540Z-2.358
    N2110G1X-34.323Y-4.504Z-2.394
    N2120G1X-34.664Y-4.431Z-2.467
    N2130G1X-35.146Y-4.285Z-2.613
    N2140G1X-35.514Y-4.154Z-2.768
    N2150G1X-35.807Y-4.051Z-2.923
    N2160G1X-36.297Y-3.877Z-3.233
    N2170G1X-36.316Y-3.508Z-3.082
    N2180G1X-36.313Y-3.081Z-2.932
    N2190G1X-36.267Y-2.541Z-2.781
    N2200G1X-36.205Y-2.170Z-2.706
    N2210G1X-36.147Y-1.913Z-2.669
    N2220G1X-35.964Y-1.332Z-2.631
    N2230G1X-31.187Y11.264Z-2.574
    N2240G1X-30.478Y13.210Z-2.539
    N2250G1X-29.812Y15.149Z-2.465
    N2260G1X-29.188Y17.090Z-2.352
    N2270G1X-28.598Y19.058Z-2.197
    N2280G1X-28.486Y19.391Z-2.183
    N2290G1X-28.266Y19.873Z-2.215
    N2300G1X-28.158Y20.066Z-2.247
    N2310G1X-27.987Y20.332Z-2.311
    N2320G1X-27.711Y20.695Z-2.439
    N2330G1X-27.341Y20.783Z-2.351
    N2340G1X-27.079Y20.827Z-2.307
    N2350G1X-26.448Y20.871Z-2.263
    N2360G1X-25.913Y20.840Z-2.294
    N2370G1X-25.691Y20.808Z-2.326
    N2380G1X-25.377Y20.745Z-2.389
    N2390G1X-24.934Y20.618Z-2.516
    N2400G1X-24.709Y20.303Z-2.428
    N2410G1X-24.567Y20.073Z-2.383
    N2420G1X-24.283Y19.495Z-2.339
    N2430G1X-23.560Y17.474Z-2.436
    N2440G1X-22.808Y15.438Z-2.511
    N2450G1X-21.936Y13.147Z-2.571
    N2460G1X-16.279Y-1.269Z-2.796
    N2470G1X-16.100Y-1.802Z-2.833
    N2480G1X-16.034Y-2.058Z-2.869
    N2490G1X-15.960Y-2.428Z-2.941
    N2500G1X-15.895Y-2.969Z-3.085
    N2510G1X-15.875Y-3.397Z-3.229
    N2520G1X-15.880Y-3.766Z-3.373
    N2530G00Z6.000
    N2540G1Z-3.373F762.0
    N2550G1X-15.638Y-4.018Z-3.245F2540.0
    N2560G1X-15.373Y-4.326Z-3.116
    N2570G1X-15.064Y-4.742Z-2.988
    N2580G1X-14.870Y-5.046Z-2.924
    N2590G1X-14.746Y-5.266Z-2.891
    N2600G1X-14.464Y-5.870Z-2.860
    N2610G1X-10.059Y-16.961Z-2.984
    N2620G1X-12.108Y-19.945Z0.000
    N2630G1X-10.059Y-16.961Z-2.984
    N2640G1X-5.614Y-19.945Z0.000
    N2650G1X-10.059Y-16.961Z-2.984
    N2660G1X-14.486Y-5.815Z-2.859
    N2670G1X-14.746Y-5.266Z-2.891
    N2680G1X-14.870Y-5.046Z-2.924
    N2690G1X-15.064Y-4.742Z-2.988
    N2700G1X-15.373Y-4.326Z-3.116
    N2710G1X-15.638Y-4.018Z-3.245
    N2720G1X-15.880Y-3.766Z-3.373
    N2730G1X-15.875Y-3.397Z-3.229
    N2740G1X-15.895Y-2.969Z-3.085
    N2750G1X-15.960Y-2.428Z-2.941
    N2760G1X-16.034Y-2.058Z-2.869
    N2770G1X-16.100Y-1.802Z-2.833
    N2780G1X-16.279Y-1.269Z-2.796
    N2790G1X-21.936Y13.147Z-2.571
    N2800G1X-22.808Y15.438Z-2.511
    N2810G1X-23.560Y17.474Z-2.436
    N2820G1X-24.283Y19.495Z-2.339
    N2830G1X-24.567Y20.073Z-2.383
    N2840G1X-24.709Y20.303Z-2.428
    N2850G1X-24.934Y20.618Z-2.516
    N2860G1X-23.245Y23.134Z0.000
    N2870G1X-24.934Y20.618Z-2.516
    N2880G1X-25.377Y20.745Z-2.389
    N2890G1X-25.691Y20.808Z-2.326
    N2900G1X-25.913Y20.840Z-2.294
    N2910G1X-26.448Y20.871Z-2.263
    N2920G1X-27.079Y20.827Z-2.307
    N2930G1X-27.341Y20.783Z-2.351
    N2940G1X-27.711Y20.695Z-2.439
    N2950G1X-29.386Y23.134Z0.000
    N2960G1X-27.711Y20.695Z-2.439
    N2970G1X-27.987Y20.332Z-2.311
    N2980G1X-28.158Y20.066Z-2.247
    N2990G1X-28.266Y19.873Z-2.215
    N3000G1X-28.486Y19.391Z-2.183
    N3010G1X-28.598Y19.058Z-2.197
    N3020G1X-29.188Y17.090Z-2.352
    N3030G1X-29.812Y15.149Z-2.465
    N3040G1X-30.478Y13.210Z-2.539
    N3050G1X-31.187Y11.264Z-2.574
    N3060G1X-35.964Y-1.332Z-2.631
    N3070G1X-36.147Y-1.913Z-2.669
    N3080G1X-36.205Y-2.170Z-2.706
    N3090G1X-36.267Y-2.541Z-2.781
    N3100G1X-36.313Y-3.081Z-2.932
    N3110G1X-36.316Y-3.508Z-3.082
    N3120G1X-36.297Y-3.877Z-3.233
    N3130G1X-36.538Y-4.130Z-3.098
    N3140G1X-36.801Y-4.439Z-2.964
    N3150G1X-37.105Y-4.856Z-2.829
    N3160G1X-37.294Y-5.161Z-2.762
    N3170G1X-37.415Y-5.382Z-2.729
    N3180G1X-37.680Y-5.979Z-2.695
    N3190G1X-41.845Y-17.138Z-2.807
    N3200G1X-45.930Y-19.945Z0.000
    N3210G1X-41.845Y-17.138Z-2.807
    N3220G1X-39.877Y-19.945Z0.000
    N3230G1X-41.845Y-17.138Z-2.807
    N3240G1X-37.662Y-5.932Z-2.695
    N3250G1X-37.415Y-5.382Z-2.729
    N3260G1X-37.294Y-5.161Z-2.762
    N3270G1X-37.105Y-4.856Z-2.829
    N3280G1X-36.801Y-4.439Z-2.964
    N3290G1X-36.538Y-4.130Z-3.098
    N3300G1X-36.297Y-3.877Z-3.233
    N3310G1X-35.807Y-4.051Z-2.923
    N3320G1X-35.514Y-4.154Z-2.768
    N3330G1X-35.146Y-4.285Z-2.613
    N3340G1X-34.664Y-4.431Z-2.467
    N3350G1X-34.323Y-4.504Z-2.394
    N3360G1X-34.082Y-4.540Z-2.358
    N3370G1X-33.500Y-4.576Z-2.321
    N3380G1X-18.896
    N3390G1X-18.272Y-4.535Z-2.363
    N3400G1X-18.014Y-4.493Z-2.405
    N3410G1X-17.649Y-4.409Z-2.489
    N3420G1X-17.133Y-4.242Z-2.656
    N3430G1X-16.735Y-4.091Z-2.835
    N3440G1X-16.416Y-3.970Z-3.015
    N3450G1X-15.880Y-3.766Z-3.373
    N3460G00Z6.000
    N3470G00X-5.741Y20.283
    N3480G1Z-2.851F762.0
    N3490G1X-3.733Y23.134Z0.000F2540.0
    N3500G1X-5.741Y20.283Z-2.851
    N3510G1X-9.904Y23.134Z0.000
    N3520G1X-5.741Y20.283Z-2.851
    N3530G1X5.827Y-10.790Z-2.413
    N3540G1X6.451Y-12.528Z-2.366
    N3550G1X7.034Y-14.200Z-2.306
    N3560G1X7.651Y-16.018Z-2.225
    N3570G1X7.893Y-16.539Z-2.262
    N3580G1X8.013Y-16.748Z-2.299
    N3590G1X8.204Y-17.034Z-2.373
    N3600G1X8.514Y-17.424Z-2.521
    N3610G1X6.787Y-19.945Z0.000
    N3620G1X8.514Y-17.424Z-2.521
    N3630G1X8.869Y-17.502Z-2.443
    N3640G1X9.120Y-17.541Z-2.404
    N3650G1X9.726Y-17.579Z-2.366
    N3660G1X10.322Y-17.542Z-2.403
    N3670G1X10.569Y-17.504Z-2.441
    N3680G1X10.918Y-17.429Z-2.516
    N3690G1X12.635Y-19.945Z0.000
    N3700G1X10.918Y-17.429Z-2.516
    N3710G1X11.231Y-17.040Z-2.366
    N3720G1X11.423Y-16.753Z-2.292
    N3730G1X11.545Y-16.545Z-2.254
    N3740G1X11.790Y-16.022Z-2.217
    N3750G1X12.444Y-14.124Z-2.300
    N3760G1X13.046Y-12.425Z-2.359
    N3770G1X13.669Y-10.721Z-2.399
    N3780G1X25.555Y20.441Z-2.693
    N3790G1X29.502Y23.134Z0.000
    N3800G1X25.555Y20.441Z-2.693
    N3810G1X23.684Y23.134Z0.000
    N3820G1X25.555Y20.441Z-2.693
    N3830G1X13.669Y-10.721Z-2.399
    N3840G1X13.046Y-12.425Z-2.359
    N3850G1X12.444Y-14.124Z-2.300
    N3860G1X11.790Y-16.022Z-2.217
    N3870G1X11.545Y-16.545Z-2.254
    N3880G1X11.423Y-16.753Z-2.292
    N3890G1X11.231Y-17.040Z-2.366
    N3900G1X10.918Y-17.429Z-2.516
    N3910G1X10.569Y-17.504Z-2.441
    N3920G1X10.322Y-17.542Z-2.403
    N3930G1X9.726Y-17.579Z-2.366
    N3940G1X9.120Y-17.541Z-2.404
    N3950G1X8.869Y-17.502Z-2.443
    N3960G1X8.514Y-17.424Z-2.521
    N3970G1X8.204Y-17.034Z-2.373
    N3980G1X8.013Y-16.748Z-2.299
    N3990G1X7.893Y-16.539Z-2.262
    N4000G1X7.651Y-16.018Z-2.225
    N4010G1X7.034Y-14.200Z-2.306
    N4020G1X6.451Y-12.528Z-2.366
    N4030G1X5.827Y-10.790Z-2.413
    N4040G1X-5.741Y20.283Z-2.851
    N4050G00Z6.000
    N4060G00X38.435Y20.284
    N4070G1Z-2.850F762.0
    N4080G1Y-17.095F2540.0
    N4090G1X35.585Y-19.945Z0.000
    N4100G1X38.435Y-17.095Z-2.850
    N4110G1X41.285Y-19.945Z0.000
    N4120G1X38.435Y-17.095Z-2.850
    N4130G1Y20.284
    N4140G1X41.285Y23.134Z0.000
    N4150G1X38.435Y20.284Z-2.850
    N4160G1X35.585Y23.134Z0.000
    N4170G1X38.435Y20.284Z-2.850
    N4180G00Z6.000
    N4190G00X54.506Y19.963
    N4200G1Z-3.171F762.0
    N4210G1X54.845Y20.120Z-3.014F2540.0
    N4220G1X55.247Y20.277Z-2.857
    N4230G1X55.771Y20.435Z-2.699
    N4240G1X56.142Y20.513Z-2.621
    N4250G1X56.404Y20.553Z-2.581
    N4260G1X57.036Y20.592Z-2.542
    N4270G1X66.165Y20.592Z-2.542
    N4280G1X67.406Y20.579Z-2.544
    N4290G1X68.621Y20.539Z-2.550
    N4300G1X69.761Y20.472Z-2.559
    N4310G1X70.832Y20.376Z-2.571
    N4320G1X72.005Y20.220Z-2.592
    N4330G1X72.784Y20.078Z-2.604
    N4340G1X73.677Y19.857Z-2.617
    N4350G1X74.476Y19.603Z-2.637
    N4360G1X74.991Y19.405Z-2.655
    N4370G1X75.498Y19.186Z-2.676
    N4380G1X76.089Y18.891Z-2.702
    N4390G1X76.851Y18.445Z-2.730
    N4400G1X77.417Y18.063Z-2.751
    N4410G1X77.867Y17.724Z-2.767
    N4420G1X78.642Y17.055Z-2.790
    N4430G1X79.361Y16.336Z-2.813
    N4440G1X79.969Y15.643Z-2.829
    N4450G1X80.593Y14.830Z-2.840
    N4460G1X81.062Y14.140Z-2.846
    N4470G1X81.588Y13.261Z-2.845
    N4480G1X81.999Y12.459Z-2.849
    N4490G1X82.401Y11.541Z-2.855
    N4500G1X82.762Y10.566Z-2.862
    N4510G1X83.075Y9.542Z-2.874
    N4520G1X83.350Y8.450Z-2.886
    N4530G1X83.503Y7.701Z-2.893
    N4540G1X83.660Y6.796Z-2.906
    N4550G1X83.843Y5.334Z-2.918
    N4560G1X83.925Y4.402Z-2.928
    N4570G1X83.998Y2.781Z-2.934
    N4580G1X84.011Y1.824Z-2.939
    N4590G1X83.990Y0.586Z-2.938
    N4600G1X83.927Y-0.664Z-2.934
    N4610G1X83.822Y-1.876Z-2.928
    N4620G1X83.674Y-3.049Z-2.919
    N4630G1X83.459Y-4.301Z-2.909
    N4640G1X83.244Y-5.279Z-2.893
    N4650G1X82.958Y-6.335Z-2.873
    N4660G1X82.635Y-7.342Z-2.858
    N4670G1X82.229Y-8.422Z-2.848
    N4680G1X81.884Y-9.219Z-2.835
    N4690G1X81.448Y-10.099Z-2.821
    N4700G1X80.947Y-10.976Z-2.806
    N4710G1X80.448Y-11.728Z-2.783
    N4720G1X79.839Y-12.532Z-2.763
    N4730G1X79.283Y-13.177Z-2.744
    N4740G1X78.642Y-13.829Z-2.727
    N4750G1X78.117Y-14.291Z-2.713
    N4760G1X77.440Y-14.805Z-2.701
    N4770G1X76.979Y-15.110Z-2.688
    N4780G1X76.366Y-15.463Z-2.671
    N4790G1X75.564Y-15.858Z-2.652
    N4800G1X75.019Y-16.090Z-2.636
    N4810G1X74.381Y-16.328Z-2.618
    N4820G1X73.650Y-16.562Z-2.599
    N4830G1X72.870Y-16.771Z-2.584
    N4840G1X71.806Y-16.993Z-2.575
    N4850G1X71.066Y-17.113Z-2.568
    N4860G1X70.291Y-17.213Z-2.563
    N4870G1X69.343Y-17.301Z-2.557
    N4880G1X68.346Y-17.362Z-2.552
    N4890G1X66.865Y-17.399Z-2.546
    N4900G1X57.036Y-17.403Z-2.542
    N4910G1X56.404Y-17.364Z-2.581
    N4920G1X56.142Y-17.324Z-2.621
    N4930G1X55.771Y-17.246Z-2.699
    N4940G1X55.247Y-17.088Z-2.857
    N4950G1X54.845Y-16.931Z-3.014
    N4960G1X54.506Y-16.774Z-3.171
    N4970G1X54.346Y-16.214Z-3.011
    N4980G1X54.266Y-15.818Z-2.931
    N4990G1X54.226Y-15.537Z-2.890
    N5000G1X54.186Y-14.861Z-2.850
    N5010G1Y18.050
    N5020G1X54.226Y18.726Z-2.890
    N5030G1X54.266Y19.007Z-2.931
    N5040G1X54.346Y19.403Z-3.011
    N5050G1X54.506Y19.963Z-3.171
    N5060G00Z6.000
    N5070G00Y-16.774
    N5080G1Z-3.171F762.0
    N5090G1X54.845Y-16.931Z-3.014F2540.0
    N5100G1X55.247Y-17.088Z-2.857
    N5110G1X55.771Y-17.246Z-2.699
    N5120G1X56.142Y-17.324Z-2.621
    N5130G1X56.404Y-17.364Z-2.581
    N5140G1X57.036Y-17.403Z-2.542
    N5150G1X67.301Y-17.394Z-2.546
    N5160G1X68.651Y-17.346Z-2.556
    N5170G1X69.488Y-17.290Z-2.559
    N5180G1X70.386Y-17.201Z-2.563
    N5190G1X71.302Y-17.078Z-2.568
    N5200G1X72.176Y-16.923Z-2.575
    N5210G1X73.187Y-16.691Z-2.593
    N5220G1X73.830Y-16.509Z-2.605
    N5230G1X74.500Y-16.286Z-2.621
    N5240G1X75.192Y-16.019Z-2.639
    N5250G1X75.861Y-15.720Z-2.657
    N5260G1X76.562Y-15.356Z-2.678
    N5270G1X77.120Y-15.019Z-2.691
    N5280G1X77.706Y-14.614Z-2.704
    N5290G1X78.260Y-14.172Z-2.717
    N5300G1X78.779Y-13.696Z-2.729
    N5310G1X79.450Y-12.993Z-2.751
    N5320G1X79.997Y-12.334Z-2.766
    N5330G1X80.595Y-11.516Z-2.792
    N5340G1X81.056Y-10.795Z-2.808
    N5350G1X81.521Y-9.961Z-2.824
    N5360G1X81.945Y-9.087Z-2.838
    N5370G1X82.328Y-8.173Z-2.848
    N5380G1X82.680Y-7.210Z-2.860
    N5390G1X83.043Y-6.043Z-2.882
    N5400G1X83.276Y-5.150Z-2.895
    N5410G1X83.505Y-4.062Z-2.909
    N5420G1X83.691Y-2.935Z-2.920
    N5430G1X83.833Y-1.770Z-2.928
    N5440G1X83.946Y-0.372Z-2.938
    N5450G1X83.995Y0.709Z-2.939
    N5460G1X84.010Y1.948Z-2.937
    N5470G1X83.990Y3.138Z-2.936
    N5480G1X83.911Y4.575Z-2.925
    N5490G1X83.814Y5.621Z-2.919
    N5500G1X83.624Y7.017Z-2.901
    N5510G1X83.457Y7.944Z-2.893
    N5520G1X83.174Y9.179Z-2.876
    N5530G1X82.925Y10.060Z-2.867
    N5540G1X82.587Y11.060Z-2.858
    N5550G1X82.204Y12.014Z-2.850
    N5560G1X81.781Y12.898Z-2.848
    N5570G1X81.269Y13.811Z-2.845
    N5580G1X80.803Y14.531Z-2.845
    N5590G1X80.222Y15.328Z-2.834
    N5600G1X79.529Y16.153Z-2.816
    N5610G1X79.042Y16.669Z-2.803
    N5620G1X78.377Y17.295Z-2.783
    N5630G1X77.773Y17.797Z-2.764
    N5640G1X77.282Y18.160Z-2.748
    N5650G1X76.701Y18.540Z-2.727
    N5660G1X75.882Y18.997Z-2.690
    N5670G1X75.383Y19.238Z-2.672
    N5680G1X74.753Y19.502Z-2.650
    N5690G1X74.026Y19.754Z-2.630
    N5700G1X73.252Y19.970Z-2.614
    N5710G1X72.631Y20.110Z-2.602
    N5720G1X71.712Y20.265Z-2.584
    N5730G1X70.397Y20.419Z-2.569
    N5740G1X69.465Y20.493Z-2.558
    N5750G1X68.449Y20.547Z-2.550
    N5760G1X67.343Y20.581Z-2.544
    N5770G1X66.087Y20.592Z-2.542
    N5780G1X57.036
    N5790G1X56.404Y20.553Z-2.581
    N5800G1X56.142Y20.513Z-2.621
    N5810G1X55.771Y20.435Z-2.699
    N5820G1X55.247Y20.277Z-2.857
    N5830G1X54.845Y20.120Z-3.014
    N5840G1X54.506Y19.963Z-3.171
    N5850G1X51.335Y23.134Z0.000
    N5860G1X54.506Y19.963Z-3.171
    N5870G1X54.346Y19.403Z-3.011
    N5880G1X54.266Y19.007Z-2.931
    N5890G1X54.226Y18.726Z-2.890
    N5900G1X54.186Y18.050Z-2.850
    N5910G1Y-14.861
    N5920G1X54.226Y-15.537Z-2.890
    N5930G1X54.266Y-15.818Z-2.931
    N5940G1X54.346Y-16.214Z-3.011
    N5950G1X54.506Y-16.774Z-3.171
    N5960G1X51.335Y-19.945Z0.000
    N5970G1X54.506Y-16.774Z-3.171
    N5980G00Z6.000
    N5990G00Z20.000
    N6000G00X0.000Y0.000
    N6010M09
    N6020M30
    Try this if it`s the one you meant
    Apr 2017
    77
    Thanks for looking at that.
    It works fine if i set the homing position to the centre but i would prefer to set it from the Left corner.
    I did set the homing position to the left in the material settings on vcarve.
    Jul 2016
    660
    Quote Originally Posted by dfox1787 View Post
    Meaning to say sir your CNC machine is not calibrated (XYZ) I suggest you calibrate it again all the axis, if you want it to run 100mm on Y axis it should run @ 100mm then stop, same on all the axis because your code is fine on my end.
    Apr 2017
    77
    Quote Originally Posted by KH0UJ View Post
    thank you sorted now. appreciated
  1. Help Setting up 4th rotary axis with Gecko 540, Mach3 and Vectric VCarve Pro
    By rdlambert1 in forum Mentors & Apprentice Locator
    Last Post: 07-23-2015, 08:28 PM
  2. VCarve pro to Mach3
    By Pysiek in forum PhotoVCarve and VCarve Pro
    Last Post: 12-16-2013, 06:16 PM
  3. Replies: 0
    Last Post: 06-18-2012, 09:46 AM
  4. mach3 and the vcarve? the pass after
    By topline in forum Mach Mill
    Last Post: 06-12-2012, 12:08 AM
  5. Biesse and Vcarve (and a bit of MACH3)
    By Matt Ribble in forum CNC Machining Centers
    Last Post: 05-29-2011, 10:38 PM
