586,377 active members*
2,418 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > EdgeCAM 2017 R1
    Jun 2009
    7
    EdgeCAM 2017 R1
    I can't find the info icon on setup after switch to manufacturing mode, although it was found in Edgecam 2016 R2.
    Any ideas
    Oct 2003
    127
    Re: EdgeCAM 2017 R1
    you dont have to "switch" like before.
    select your machine by clicking "create sequence" then select the "machining" tab above that, select your tool and roll.
    the tabs "setup-features-machining-NC code" are the toggles you are thinking of and they are more fluid now instead of on/off like it use to be
    Jun 2009
    7
    Re: EdgeCAM 2017 R1
    Quote Originally Posted by timf View Post
    your powerful note is like the magic key that make the info icon still available.
    and that works on the new files but not applicable for old ones. is there any recommendations to make info icon appear on the old files?
    Dec 2008
    441
    Re: EdgeCAM 2017 R1
    But cant you just open the old files and do programming?
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
  1. Edgecam 2016-2017 Impeller advanced 5 axis
    By Vegabond in forum EdgeCam
    Last Post: 05-22-2017, 08:21 PM
  2. Chencan CNC DubaiWoodShow 2017
    By ESKA in forum Trade Shows / Webinars / Other Events
    Last Post: 02-14-2017, 02:32 AM
  3. New CAM Feature of ZW3D 2017
    By Seanyaohan in forum ZW3D CAM
    Last Post: 12-29-2016, 12:18 AM
  4. ZW3D 2017
    By Seanyaohan in forum Uncategorised CAD Discussion
    Last Post: 09-20-2016, 08:35 AM
  5. ZW3D 2017
    Last Post: 09-20-2016, 08:34 AM
