586,598 active members*
3,565 visitors online*
Results 1 to 10 of 10
    Apr 2017
    6
    DIY Clamping Methods?
    I am attempting to build a machine that can work on 4' x 8' pieces of wood and plastic. I think I have figured out how I want to build my moving assembly. Now I'm trying to figure out the best route to go for clamping actual work pieces down.. After looking at many other builds, I'm definitely in the low budget category. I think ultra low cost way to go would be to just mill t slots in some wood. I however don't see this holding up very long to repeated t nut tightening. I see a lot of people do vacuum tables, but i haven't researched the cost and it seems like you almost want a working cnc machine to make it lol. Perhaps ill eventually make one, but until then, what options do I have that fall in the low budget category for clamping?
    Re: DIY Clamping Methods?
    Screws and nails into the spoilboard.
    T nuts in the spoilboard.
    Nov 2008
    79
    You can do high quality work using low quality clamps.......if you are careful. And got lots of time.
    John C
    carpenterswoodworking.com
    Apr 2009
    5516
    They make composite pins that you can. throw in your pin gun, great to hold waste material or paint grade stuff. I use screws into the spoilboard. Evwry once in a while a litlle Bondo and a surface pass gets the table nice and smooth.
    Nov 2011
    205
    What kind of cutter do you use for resurfacing ???
    Don
    Apr 2009
    5516
    Quote Originally Posted by DonKes View Post
    Don
    https://www.amanatool.com/45566-carb...ar-design.html
    Nov 2010
    520
    I made some clamps from scraps. Wood is a lot more forgiving then steel when you crash into it with your end mill.
    Apr 2007
    663
    Found this on youtube..
    Best of both worlds: vacuum and t-track
    https://www.youtube.com/watch?v=5hKCy8TkUJo
    Nov 2014
    20
    I am building a vac table now. Used the solsylva video on utube. Hope to finish this week. Mines 50x58
    Sent from my SM-G930P using Tapatalk
    Jul 2016
    660
    Use a home made jig (steel or plastic) if you want to cut thousands of the same output
    Attachment 359984
  1. Entry Methods
    By FuriousGeorge in forum Tormach Personal CNC Mill
    Last Post: 09-11-2013, 05:58 PM
  2. Clamping methods and feeds and speeds
    By cwaugs in forum Uncategorised MetalWorking Machines
    Last Post: 05-21-2011, 11:43 PM
  3. clamping methods?
    By Crawler374 in forum DIY CNC Router Table Machines
    Last Post: 12-08-2009, 12:44 PM
  4. Test methods
    By guhl in forum Fanuc
    Last Post: 12-08-2007, 10:21 AM
