586,103 active members*
3,794 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Delay for scribe
    Feb 2013
    51
    Delay for scribe
    I added a scribe plate marker to my home built table and I've got it working but I need help with how to put in a path rule. I've just been testing a couple of small circles, one inside the other and my problem is I have to have the down pressure on my slide set so low so it doesn't dig in that it hasn't reached the table before the X,Y starts to move.
    On the small test file I've manually went in and added the G4 delays and it works fine but if I try to make a path rule near pierce it puts the delay in before the M7 code and not after. Does anyone know how to set this up so that the delay starts after my slide and scribe have started automatically?
    Thanks in advance!
    Feb 2013
    51
    Re: Delay for scribe
    For anyone that finds this down the road with the same issue Tom at CandCNC created the 11N post for the scribe so you can but delays in to compensate for the slow slide reaction.
  1. Scribe Setup How to
    By Shefron in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 10-20-2017, 10:26 AM
  2. The Jeweler air scribe attachment
    By BTA PLASMA in forum Bulltear Industries Support Forum
    Last Post: 03-09-2017, 04:02 AM
  3. Adding a scribe
    By usweldpro in forum Waterjet General Topics
    Last Post: 08-20-2014, 04:54 PM
  4. scribe with hypertherm 260 amp
    By 2brad4u in forum Community Club House
    Last Post: 05-04-2012, 04:48 PM
  5. mold scribe lines with 9.1
    By juxtoposed in forum Mastercam
    Last Post: 05-29-2011, 09:59 PM
