586,089 active members*
3,757 visitors online*
IndustryArena Forum > CAM Software > CamBam > Milling 3d part settings
Results 1 to 10 of 10
    Apr 2017
    11
    Hi there,
    I just started using Cambam and it is my first experience with a cnc milling machine. I built my own one and I am using Mach3.
    I have already experienced some machining with simple parts and some engraving, now I am trying to machine a 3d part and I have set Cambam as per pictures here below. Sorry if the pictures appear rotated 90° but I am unable to post them straight.
    The result I am having looks quite messy, despite the fact hat I have set depth increment 0.5 mm I see the tool going quite deep (7 mm) since the beginning. I do not understand why?
    Moreover I would like the part to be machined layer by layer (0.5 mm each) with the router scanning the part left to right and back and not left to right than lift back and start again.
    I would appreciate help and hints on how to achieve the above and solve the depth issues.
    Thanks in advance
    Dec 2008
    292
    Re: Milling 3d part settings
    You need to use Waterline Rough with a small clearance to do the 'rough' shaping then a second Waterline Finish to do the final shaping. Rough will step down in increments, Finish will follow the full depth for each pass. To mill both directions change Milling direction to 'mixed'.
    You will receive much faster responses to help requests if you use the CamBam support website. Probably the best help support I have experienced with any software package. You usually get answers very quickly. Few CamBam users follow this site.
    Don
    Apr 2017
    11
    Thank you for your hints. Will try.
    As far as cncerning the Cambam forum I have experienced quite a lot of ego going on there.
    Nov 2012
    1267
    Which version of CamBam are you using, 0.9.8 or 1.0 Beta? The Beta has this exact problem with 3D profile operation - it plunges at full depth instead of obeying the depth increment value.
    Apr 2017
    11
    I am using the latest stable version 0.9.8
    I did some test and I discovered that the issue is caused by the Roughing/Finishing setting. I was using "finishing" straight away and this cause the machining to start at full depth (I found evidence of this in the documentation). I am not happy about this because the increment setting is overridden without any alert to the user however it is like this and I assume shall be accepted as it is. I would have made the software to automatically change the depth increment value to the full depth when the "Finishing" is selected so there is not a fake value prompt to the user which leads to mistakes. But thats me.
    By the way, I am still in trial mode so I still have a couple of weeks before I decide to buy it. Are you happy of cambam?
    Nov 2012
    1267
    Well, it makes sense: in finishing mode you do not need to go layer by layer because the bulk of the stock material has already been removed. But I agree, CamBam should make it more clear which values apply to the current operation, which ones do not matter, and which ones are overridden.
    And yes, I am very happy with CamBam - although I mostly do 2D and 2.5D stuff such as engraving, printed circuit boards and flat parts.
    Nov 2008
    412
    Quote Originally Posted by FeliceM View Post
    REALLY!
    You must first one to say this...
    Forget about global warming...Visualize using your turn signal!
    Dec 2013
    5717
    I have had CamBam for about 4 years and am very satisfied with it. I also use Fusion 360 and have MasterCam on one computer. But I use CamBam for simple stuff because it's so easy to use. I normally can set up even a somewhat complex 2.5 D part in about 5 minutes.
    Dec 2008
    292
    I am sorry you got that impression. I have found the group to be extremely helpful and amazingly fast. My original point was that few people use CNCZone for their support for CamBam and any help you need will probably come faster on the CamBam site rather than here on CNCZone. When I responded to you it was the first time in probably 6 months that I even looked at this site.
    Don
    Apr 2017
    11
    Thank you. Your advice is appreciated.
  1. I bought a CNC Milling Machine 3020T/ settings problem maybe.
    By poolrod2 in forum CNC Machining Centers
    Last Post: 09-22-2016, 04:48 AM
  2. Stock part settings and other questions
    By cncadmin in forum BobCAM for SolidWorks™
    Last Post: 12-16-2013, 11:52 PM
  3. Edgecam 2012 Settings and Milling Sequences
    By NFPprogrammer in forum EdgeCam
    Last Post: 08-31-2012, 10:42 AM
  4. Practical X3 Milling Settings
    By TaK in forum Benchtop Machines
    Last Post: 02-15-2011, 04:04 AM
  5. Part holding and milling 3D part on 2.5D Mill?
    By john_t_h in forum MetalWork Discussion
    Last Post: 03-15-2008, 12:35 PM
