586,102 active members*
2,462 visitors online*
    Jan 2011
    10
    Coolant foaming ?
    Hey all. Kind of new here. I have two okuma genos L- 250's. Running the same coolant in both. Mix's are good and the same in both. One machine is fine, the other foams. Foaming fairly good. What would cause one machine to foam and the other is fine? Don't know if it makes a difference, one machine runs only steel and the machine that foams runs only copper. This foam has been there on and off, but lately foaming a lot more and not going away.
    Dec 2013
    5717
    Re: Coolant foaming ?
    Maybe the coolant pump sucking air somewhere? Maybe copper reacting with the coolant? Try some hot tub anti-foam, available at your local hot tub / spa supply, or your local Walmart.
    Jan 2011
    10
    Figured out what was going on. Real fine chips getting around the screen that covers the pump intake. Went ahead and took the old coolant out, cleaned the tank, removed the pump and cleaned all the screens around it. Works fine now.
    Hi why not installing a dust collector on your cnc router ?
  1. Coolant foaming problem
    By Larry Myers in forum Sharp CNC
    Last Post: 01-26-2016, 09:55 PM
  2. New oil foaming instantly - is it expected?
    By Steelmesh in forum Charter Oak Automation Support Forum
    Last Post: 03-11-2015, 06:44 PM
  3. Oil foaming.
    By BlackMoon in forum Charter Oak Automation Support Forum
    Last Post: 11-17-2009, 01:30 AM
  4. VMC FOAMING
    By BAD DOG in forum Daewoo/Doosan
    Last Post: 05-31-2008, 02:32 PM
