Re: Very custom X-Carve build
Originally Posted by
tinmancarving
Very well executed build.
How are you liking the DDCSV1.1?
Rob
Thank you Rob!
Actually liking the controller quite well. Of course I've not done anything too serious with it yet, but from all indications it looks like it should be great.
The DDCSV1.1 is understood to be a "mm only" controller. All the parameters & feed rates are labeled as such in the configuration pages. Ignoring that, I simply configured the motors as "steps per inch" rather than "steps per mm", and it works fine that way. The 3 decimal place display is perfect for a router.
- Bill
<a href="http://www.cnczone.com/forums/mini-lathe/82871-7-x-10-project-started.html" target="_blank">7X10 Lathe conversion</a>
<a href="http://www.cnczone.com/forums/open-source-cnc-machine-designs/335846-cnc.html" target="_blank">Custom X-Carve router</a>
<a href="http://www.linkedin.com/in/tooldesign" target="_blank">LinkedIn</a>
