Hello all, it's been several years since I've been active on here. My last project was a 7 x 10 lathe
I'm back again, this time with a custom X-carve. I started with a 1000 x 1000 machine, and shortened the Y-axis to 635mm. Due to lack of space, I wanted it to fit on a nice worktable I already had. Once I had the basic machine built, I started wondering about controls, and mounting all the various components I needed. Then I looked on the other side of my garage at a tool cart that had (operative word here) a nice 4-drawer module that was relatively easy to remove from the cart, just drilling out a few rivets.
I basically turned the bottom drawer into my electrical cabinet. I'm using a DDCSV1.1 CNC controller mounted in one of the top drawers. The way it's mounted, it just clears to close, then hinges up to latch into place at a nice viewing angle, into the aluminum extrusion. It feeds the signals to the G540. I also added LED light strips under the X carriage. The base work surface is a piece of 7 ga. (.179) mild steel with 1/4-20 tapped holes in a 3" grid. The top board is just a piece of particle board with clearance holes drilled thru to match the tapped hole pattern.
Here's the build, hope you enjoy the pics!
Attachment 361198
Attachment 361196
Attachment 361200
Attachment 361202
Attachment 361204
Attachment 361206
Attachment 361208
