586,117 active members*
3,434 visitors online*
Results 1 to 7 of 7
    Jul 2016
    660
    CO2 Glass Laser Refill
    Anyone tried refilling their glass tubes? I wanna try it since we have almost 50 pcs. depleted 60 watts glass tubes, I wanna try the continuous and the sealed type, im finding a hard time purchasing a helium gas in our area, I tried purchasing a laser mix in alibaba but they need the gas mixture percentage, I cannot give them since I havent tried experimenting yet on what`s the optimum mixture, I have all the tools and equipment to do the job since im a refrigeration guy for 17 years (vacuum pump, access valves, charging gauges, etc) according to my research I only need 2 psi of mix gas, is it correct? or anyone point me in the right direction on purchasing a laser mix gas for 60W laser tubes.
    I also want to refill a synrad 75W RF tube, we have one weak unit here in the shop, I dismantled it and studied it`s constructions and learned from it, it uses two RF amplifiers for energizing the laser mix gas, again I dont know what`s the mixture, analyzing it`s o-ring design probably it can hold only up to 5-10 psi since the charging port is only the two terminal posts on the RF amplifier with a square O-ring, any tips on what`s the mixture on these kind of laser?
    Pressures, gases, high voltages and high power radio frequencies are not new to me, I can handle thousands of psi of gases with ease I can touch 40K high voltage bare hands without dying :rainfro: the trick in high voltage is to insulate yourself from earth ground (2-3 inches), it can sting but surely it cant kill you.
    My aim on refilling is to optimize the tubes itself to be more powerful from stock and refillable. because china ships tubes here out of 10 tubes sometimes the 2 tubes are weak, sometimes 4 weak tubes. we buy tubes by tens to compensate the customs charges.
    Jul 2016
    660
    Re: CO2 Glass Laser Refill
    anyone wanna help?
    Nov 2010
    787
    Write me at [email protected]
    CNC lasers, constructions, service
    Jul 2019
    Hello cinematic2,
    I'm from Poland too. Do you maybe have any idea-fix for RF tubes too?
    Best
    Radek
    Mar 2011
    6
    i have complete setup for CO2 laser sealed glass tube, i can refill gas in this tubes, i got gas mix ratio business secrete
    i want to sell the hole know how, so some one can start business, i am getting retired.
    contact me on 00447507433430 Ranjan Kumar
    Dec 2019
    Hi, I just wonder if you had any helpful suggestions, cause I am in a very similar position than you,
    Regards
    Aug 2015
    142
    There u find the secrete recipe for laser refill https://www.youtube.com/watch?v=NZ4wnXxEQ_s
  1. Synrad Laser Tube for the universal Versa Laser VL 200 Recharge / Refill
    By Lorrie1983 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-15-2019, 02:14 PM
  2. Coherent Deos Gem Laser Tube Refill / Recharge ?
    By blugraphic in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 05-03-2017, 09:46 AM
  3. RF Excited Co2 Laser refill
    By pinal in forum News Announcements
    Last Post: 06-27-2013, 05:07 PM
  4. RF-excited CO2 Laser Tube Refill near NYC tri-state area?
    By jeaves in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-01-2011, 03:23 PM
