586,619 active members*
2,460 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G320X Setup and Tuning Videos
    Jan 2007
    467
    I promised these videos a while ago and they are finally uploaded and good to go. There are two videos covered here; the first one is a basic setup video on testing and running your G320X out of the box and the second video is how to tune it quickly with an oscilloscope.
    https://www.youtube.com/watch?v=0k3c...ature=youtu.be
    https://www.youtube.com/watch?v=mo-w...ature=youtu.be
    Let me know if you guys have any questions or complaints about the videos and I will be happy to answer them!
    Marcus Freimanis
    www.geckodrive.com
    Nov 2008
    412
    Re: G320X Setup and Tuning Videos
    Awesome Video, That helps alot, THANK YOU!
    I see only one channel is used? Is that correct?
    The dip switches were in default settings?
    Thanks.
    Forget about global warming...Visualize using your turn signal!
    Jan 2007
    467
    That is correct on all questions. The G320X uses only single-ended encoders and does not use the index wire. All switches were in their default position to make things as simple as possible.
    Marcus Freimanis
    www.geckodrive.com
  1. G320X Tuning..
    By lancut in forum Gecko Drives
    Last Post: 01-31-2017, 04:32 PM
  2. G320X Tuning
    By emvali in forum Gecko Drives
    Last Post: 02-06-2015, 10:57 PM
  3. another G320x tuning question
    By CS900 in forum Gecko Drives
    Last Post: 10-21-2013, 12:48 PM
  4. G320X Servo Tuning
    By Bob La Londe in forum Gecko Drives
    Last Post: 02-19-2013, 07:05 PM
  5. G320X Tuning - Resolution
    Last Post: 09-07-2012, 07:24 PM
