586,909 active members*
3,242 visitors online*
Results 1 to 8 of 8
    40
    monitor problem
    Hi I have a Fanuc OM with 9 inch mono monitor , all the monitor characters have vertical lines in front of them , before i get a new monitor any one know if its the monitor or the fanuc computer that is generating this , it some times disappears.
    Jun 2010
    4256
    Re: monitor problem
    Looks like the graphics driver or maybe the graphics memory bus. But it could still be the display unit.
    Cheers
    Roger
    40
    Re: monitor problem
    Hi Roger , Thanks , when I look at the monitor sometimes the characters change like a refresh or a digital process and sometimes they are OK as the monitor is just composite video i dont think its the monitor , i am leaning towards your suggestions of graphics driver or memory , do know where i can look for the graphics pcb of the fanuc om
    regards peter
    Jun 2010
    4256
    Re: monitor problem
    Computers I know; Fanuc I do not know.
    Sorry. Ring Fanuc?
    You could try to find a display which takes composite video. It would be an old one though.
    Which city are you in?
    Cheers
    Roger
    Jun 2010
    4256
    Re: monitor problem
    Hum ... looking more closely at the results, I am suspecting the addressing part of the graphics memory. I suspect one of the address lines is failing.
    Cheers
    Roger
    Oct 2012
    40
    Re: monitor problem
    Quote Originally Posted by peterklos View Post
    Hi
    I can supply you LCD screen to replace the old crt, old crt will create problems so better to replace it with LCD display.
    If you are interested, please feel free to contact us.
    @:- [email protected]
    Ph:- +91 8149636586
    Regards,
    Deepak
    Sent from my vivo Y27L using Tapatalk
    Feb 2012
    126
    Re: monitor problem
    What version of the OM is it? (the number on the main board) Are you using the on board graphics or a separate card? Of the graphics on the mainboard is failing maybe you could just buy a used card? It doesn't look like a CRT problem
    Nov 2012
    1268
    Re: monitor problem
    This is definitely a video adapter problem, the monitor itself looks fine. Without knowing any specifics about Fanucs, my guesses would be:
    - A stuck bit in the video RAM.
    - A timing problem in the RAMDAC (or whatever you call a RAMDAC equivalent for a monochrome display adapter).
  1. Haas Monitor Problem, any help
    By MitchMRP in forum Haas Mills
    Last Post: 01-05-2020, 08:41 AM
  2. crt monitor problem
    By jsync in forum Norwegian
    Last Post: 01-19-2016, 12:43 AM
  3. Monitor problem
    By TRIMI in forum Hitachi Seikis
    Last Post: 11-20-2014, 02:58 PM
  4. Biesse 336 monitor problem
    By sercab1 in forum CNC Machining Centers
    Last Post: 02-24-2011, 08:02 PM
  5. Monitor problem
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 02-28-2005, 04:51 PM
