586,110 active members*
3,257 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > OI-MC series -- FOCAS Help required to get data
Results 1 to 9 of 9
    May 2017
    Hi All
    We are looking to get data out of a cnc machine that has fanuc controller (series OI-MC). The controller has a serial port and i am not sure if there is a pcmcia card slot although looking through the data sheet I believe we can add one to the controller.
    I have used Focas library earlier on latest series of CNC machines that has Ethernet out and it is quite simple.
    In the current scenario I want to know if the below is possible,
    1) can I connect to serial port of cnc machine with my laptop directly and use a focas based application to get data out of it directly.
    2) Can i use a serial to Ethernet converter and then use the Ethernet out to my laptop and use focas based application to get data out of it.
    In the 2nd point how would i know the IP address of the cnc controller.
    Re: OI-MC series -- FOCAS Help required to get data
    You can use the Embedded port on the CNC. It is located on the back side of the controller. (Behind the monitor)
    May 2017
    Thanks for your response. Are you talking about the embedded Ethernet port ??
    Should I just connect the LAN cable and use the FOCAS libraries ??
    Ethernet on the 0i-MC is an option check you have it
    depending what data you want out you can use DPRINT commands via RS232
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
    Yes, I am referring to the Fanuc sells FAS Connect to just what you want to do. They have a free 30 day Demo that you can try before you buy. D72F-0499-PB00 FAS SOLUTIONS DEMO DVD Check it out. You should have the embedded Ethernet port.
    Feb 2009
    6028
    0imc should come standard with Ethernet. Fanuc lists it as standard, high speed Ethernet is an option .
    Sent from my SM-T813 using Tapatalk
    Dec 2018
    Hello,
    For some Fanuc CNC’s we observe Focas2 inside PCMCIA option. It doesn’t has EMBED option and not even the embedded ethernet port. In such cases, how to connect and collect data using Focas2 library?
    Any reply is thankful
    Quote Originally Posted by underthetire View Post
    Hi there - I know it's been years but I have a question. I have a Fanuc 0i-MC controller on a milling machine. It has the ethernet port on the side of the controller box. I can plug in a network cable - but how do I transfer files on/off the controller? I have not been able to find any instructions yet where it connects to a network or server.
    Any help much appreciated!
    Dec 2009
    953
    hey
    look for B-64115EN/03 manual where you will find how to setup your network
  1. Replies: 12
    Last Post: 04-22-2020, 02:02 PM
  2. Program manual required for Series 21i-m
    By CNC-Hammer in forum Fanuc
    Last Post: 12-26-2014, 05:30 PM
  3. Required ROM IC's Data for FEMCO CNC Turning Center With Fanuc 10T Series
    By james anderson in forum Wood Lathes / Mills
    Last Post: 12-12-2012, 09:49 AM
  4. Fanuc Robocut alpha-OiA 18i - W series FOCAS
    By dave_the_bear in forum Fanuc
    Last Post: 09-11-2012, 09:37 PM
  5. Tape data decoding help required...
    By Danii in forum G-Code Programing
    Last Post: 11-04-2007, 08:44 PM
