586,058 active members*
3,393 visitors online*
IndustryArena Forum > CAM Software > CamWorks > help on toolist EC editor camworks
Results 1 to 11 of 11
    Nov 2004
    70
    i had my toollist post out in the begin of the program, however;
    i need to put the semicolon in front of the bracket of each tool.
    I looKed in the lib. file and master.art mill. file. can't find it. please help
    :C: GETTOOLS(2,SYSTEM)
    POST OUT
    G90 G20
    N2F
    ;N3********* TOOLLIST**********
    ( STATION TOOL TYPE DIAMETER CORNER RADIUS DESCRIPTION )
    ( 001 ENDMILL 00.500 .505 RT )
    ( 002 ENDMILL 00.250 .EM )
    N5 G00 G90 G70 G40
    N6G79 Z0
    N7G16XY
    N8M51 M52
    N9M41;M42
    N10;(DAN,YV)
    N11;(UDA,Y/V)
    N12(UTO,1,X-.5,Y.5,Z1)
    THIS IS WHAT I WANT
    ;( STATION TOOL TYPE DIAMETER CORNER RADIUS DESCRIPTION )
    ;( 001 ENDMILL 00.500 .505 RT )
    ;( 002 ENDMILL 00.250 .EM )
    SEMICOLON IN FRONT
    Feb 2010
    69
    Re: help on toolist EC editor camworks
    change your gettools command in the lib,try
    :C: GETTOOLS(2,OUTPUT_TOOL_LIST)
    add a section to configure your output in the .src
    :SECTION=OUTPUT_TOOL_LIST
    :T: <SEMICOLON><LEFT_PAR>T<"%2LNT":TOOL>=<TOOL_COMMENT ><RIGHT_PAR><EOL>
    Add semicolon to your mill.lib file
    :ATTRNAME=SEMICOLON
    :ATTRTYPE=POST
    :ATTREMARK=
    :CODETYPE=HARDCODE
    :CODE=;
    :ATTREND
    Let me know if it worked!
    Nov 2004
    70
    worked perfectly thanks you
    Nov 2004
    70
    HI
    i got my toollist working, moreover; i need to add the tool protrusion ( stickout ) in the tool list help please anybody
    (AKIRA SEIKI 2017)
    (********* TOOLLIST**********)
    ( T01= 5.4MM JOBBER DRILL )
    ( T02= .25 4 FLUTE CRB EM .)
    THIS WHAT IS NEED TO ADD TO THE TOOL LIST
    (AKIRA SEIKI 2017)
    ( T01= 5.4MM JOBBER DRILL . STICKOUT 3.8 )
    ( T02= .25 4 FLUTE CRB EM . STICKOUT 2.5 )
    TOOL_PROTRUSION
    N_TOOL_PROTRUSION
    NC_TOOL_PROTRUSION
    Type
    DECIMAL
    Usage
    This variable stores the tool protrusion from the bottom of the tool holder to the end of a mill tool or a drill tool.
    :ATTRNAME=INI TOOL PROTRUSION
    :ATTRTYPE=POST
    :ATTRVTYPE=DECIMAL
    :ATTREMARK=Z World Coordinate
    :ATTREND
    Feb 2010
    69
    :T: <SEMICOLON><LEFT_PAR>T<"%2LNT":TOOL>=<TOOL_COMMENT > STICKOUT <"#1.3":TOOL_PROTRUSION><RIGHT_PAR><EOL>
    Nov 2004
    70
    THANK YOU
    Nov 2018
    4
    EC editor camworks
    Hello I am new to this forum but have been using CamWorks for 5 years and now I have a homemade CNC 5 Axis mill that I need help with federate.
    I am familiar with G93 inverse feed but I want to put that in my .SRC file or I was wondering if I could get help with writing an "IF" command somewhere in the .SRC file. IE (IF A or B THEN F x 5= F) so it would then take the F100 x 5 for F500???
    What happens as you probably know, my rotation is snail speed as F100 in IPM turns to 100 DPM so over 3 1/2 minutes for a full rotation!
    I am also using Mach3 Software to run the mill.
    I have hand edited a file once where I had F100 as the default and every first line of a group that has an A, B move I ended it with F500. I was milling on a .5" Radius part. Any line that did not have an axis move I ended with F100 again.
    That took about 15 entries on a 2000 line file but I want this automated somehow.
    Any help would be appreciated greatly.
    Dec 2010
    126
    Re: EC editor camworks
    Quote Originally Posted by DJ1 View Post
    You should start a new topic rather than reviving an old solved one. People will not know to look here for this solution...
    Read these posts for a better understanding of inverse time feed. It is crucial to understanding the math behind it and why your desired solution is not only extremely oversimplified but also potentially dangerous. Simply multiplying the feedrate isn't going to provide predictable results and certainly not so when you get into more complicated situations. You really need to implement the proper math to produce the appropriate desired feedrate.
    Inverse Time Feedrate for 4th Axis
    G93 Inverse Time Feed Move Explained
    Once you have an understanding of how this function truly works, then you can start experimenting with your post. I can't help you much with that aspect other than to point you to the CALC_REG_F section of your GENERAL.LIB file. Copy that section to your <POST>.LIB file and edit it accordingly. It likely already has some comments regarding G94 and G93 feedrates in it. You'll have to decipher how to alter the code logic to determine when to output inverse time feed rates and when not to, and also how to enable it thu the CAMWorks GUI. Post here if you get stuck and I can try to give you more details as you go.
    Nov 2018
    4
    Japazo, Thank you for the quick reply and the .LIB tips, I will check into that.
    I'll read up on the two links you have here also.
    Quote Originally Posted by plast744 View Post
    Hi Plast744,
    I was hoping you could help me out here. I am trying to do the same thing, i would like a list of the tools used in the code to be displayed at the beginning of the code in comments, but i cannot seem to add the correct sections. I added the section to the .src file and i modified the master mill.lib file, but i am getting an error and no code is being output. The error is "Error Adding Section - no name duplicate section name = ". I believe i have to add or modify a section in the master mill.lib file, but i do not know what to change.
    Could you provide me with any guidance?
    Thanks in advance.
    Dec 2010
    126
    I am quoting Brian from the CAMWorks forums at camworks.com, so all credit here goes to him. He has helped many people to get post issues straightened out over there.
    (QUOTE)
    In .src add the following sections with these variables in the :T:…
    :SECTION=START_OUTPUT_TOOL_LIST
    :T:<LEFT_PAR><TOOL_LIST_NUM><TOOL_LIST_TYPE><TOOL_ LIST_CRAD><TOOL_LIST_CWTOOLCOM><RIGHT_PAR>
    :T:<LEFT_PAR><S_TOOL_NUM><S_TOOL_TYPE><S_TOOL_CRAD ><S_TOOL_COMMENT><RIGHT_PAR>
    In the .lib for the specific post add these variables
    :ATTRNAME=TOOL LIST NUM
    :ATTRTYPE=POST
    :ATTREMARK=
    :CODETYPE=HARDCODE
    :CODE=TOOL
    :COLUMN=3
    :ATTRSPACES=YES
    :ATTREND
    :ATTRNAME=TOOL LIST TYPE
    :ATTRTYPE=POST
    :ATTREMARK=
    :CODETYPE=HARDCODE
    :CODE=TOOL|TYPE
    :COLUMN=13
    :ATTRSPACES=YES
    :ATTREND
    :ATTRNAME=TOOL LIST CRAD
    :ATTRTYPE=POST
    :ATTREMARK=
    :CODETYPE=HARDCODE
    :CODE=CORNER|RADIUS
    :COLUMN=29
    :ATTRSPACES=YES
    :ATTREND
    :ATTRNAME=TOOL LIST CWTOOLCOM
    :ATTRTYPE=POST
    :ATTREMARK=
    :CODETYPE=HARDCODE
    :CODE=CAMWORKS|TOOL|COMMENT
    :COLUMN=50
    :ATTRSPACES=YES
    :ATTREND
    :ATTRNAME=S TOOL NUM
    :ATTRTYPE=POST
    :ATTRVTYPE=INTEGER
    :ATTRINLEN=5
    :ATTREMARK=
    :CODETYPE=FORMAT
    :VAR=TOOL
    :WORD_ADDRESS_BEF=
    :WORD_ADDRESS_AFT=
    :LEFT_PLACES=2
    :RIGHT_PLACES=0
    :UNITFLAG=NON_CONVERT
    :ATTRSPACES=YES
    :MODAL=NO
    :ATTRUSED=1
    :COLUMN=5
    :ATTREND
    :ATTRNAME=S TOOL TYPE
    :ATTRTYPE=POST
    :ATTRVTYPE=INTEGER
    :ATTREMARK=
    :CODETYPE=SELECT
    :VAR=TOOL_TYPE
    :SELECT=201
    :CODE=|FLAT ENDMILL|||||||
    :SELECT=202
    :CODE=|BALLNOSE ENDMILL|||
    :SELECT=203
    :CODE=|HOGNOSE ENDMILL||||
    :SELECT=221
    :CODE=|TAPERED ENDMILL||||
    :SELECT=222
    :CODE=|TAPERED BALLNOSE|||
    :SELECT=223
    :CODE=|TAPERED HOGNOSE||||
    :SELECT=204
    :CODE=|DRILL||||||||||||||
    :SELECT=205
    :CODE=|BORE|||||||||||||||
    :SELECT=206
    :CODE=|REAMER|||||||||||||
    :SELECT=207
    :CODE=|TAP||||||||||||||||
    :SELECT=208
    :CODE=|CENTER DRILL|||||||
    :SELECT=209
    :CODE=|CORNER ROUNDING EM|
    :SELECT=210
    :CODE=|COUNTERSINK||||||||
    :SELECT=211
    :CODE=|SINGLE PT THREAD MILL|
    :SELECT=212
    :CODE=|MULT. PT THREAD MILL||
    :SELECT=213
    :CODE=|DOVETAIL|||||||||||
    :SELECT=214
    :CODE=|KEYWAY|||||||||||||
    :SELECT=215
    :CODE=|UNKNOWN||||||||||||
    :SELECT=216
    :CODE=|LOLLIPOP|||||||||||
    :SELECT=217
    :CODE=|FACEMILL|||||||||||
    :SELECT=218
    :SELECT=301
    :CODE=|ROUND INSERT|||||||
    :SELECT=302
    :CODE=|SQUARE INSERT||||||
    :SELECT=303
    :CODE=|TRIANGLE INSERT||||
    :SELECT=304
    :CODE=|35 DEG. DIAMOND||||
    :SELECT=305
    :CODE=|55 DEG. DIAMOND||||
    :SELECT=306
    :CODE=|80 DEG. DIAMOND||||
    :SELECT=315
    :CODE=|DIAMOND INSERT|||||
    :SELECT=316
    :CODE=|THREAD INSERT||||||
    :SELECT=308
    :CODE=|GROOVE INSERT||||||
    :SELECT=309
    :SELECT=310
    :SELECT=311
    :SELECT=317
    :CODE=|TRIGON INSERT||||||
    :SELECT=318
    :CODE=|HEXAGON INSERT|||||
    :COLUMN=10
    :ATTRUSED=1
    :ATTREND
    :ATTRNAME=S TOOL CRAD
    :ATTRTYPE=POST
    :ATTRVTYPE=DECIMAL
    :ATTRINLEN=6
    :ATTREMARK=
    :CODETYPE=FORMAT
    :VAR=TOOL_CORNER_RADIUS
    :WORD_ADDRESS_BEF=
    :WORD_ADDRESS_AFT=
    :LEFT_PLACES=1
    :RIGHT_PLACES=3
    :MUST_BE_LEADING
    :MUST_BE_TRAILING
    :MUST_BE_DECIMAL
    :ATTRSPACES=YES
    :MODAL=NO
    :ATTRUSED=1
    :COLUMN=33
    :ATTREND
    :ATTRNAME=S TOOL COMMENT
    :ATTRTYPE=POST
    :ATTRVTYPE=CHARACTER
    :ATTRINLEN=100
    :ATTREMARK=
    :CODETYPE=FORMAT
    :WORD_ADDRESS_BEF=
    :VAR=TOOL COMMENT
    :WORD_ADDRESS_AFT=
    :LEFT_PLACES=0
    :RIGHT_PLACES=0
    :ATTRSPACES=YES
    :MODAL=NO
    :ATTRUSED=1
    :COLUMN=45
    :ATTREND
    Then if you don’t have the CALC_START_OF_TAPE section in your .lib for your specific post, copy it from the lathe.lib and add it.
    Then before it calls the section… IF SECTION EXIST(START_OF_TAPE) THEN CALL(START_OF_TAPE)
    Add this:
    :C: CALL(START_OUTPUT_TOOL_LIST)
    :C: GETTOOLS(2,CALC_OUTPUT_TOOL_LIST)
    Then somewhere in that .lib file, after the CALC_START_OF_TAPE add this…
    :SECTION=CALC_OUTPUT_TOOL_LIST
    :C: CALL(OUTPUT_TOOL_LIST)
    Essentially that will call a tool list header —- the START_OUTPUT_TOOL_LIST, then it will run and get tooling info for each tool and output it in the “OUTPUT_TOOL_LIST” section and keep looking for each tool there is used in that posted program.
    There are other “tool” variables you can setup in there as well, look them up in the UPG. Setup them like I did the “S_xxxxxx” variables, changing the “VAR=” to that system variable. You can then use the “FORMATS” like these:
    :WORD_ADDRESS_BEF=
    :WORD_ADDRESS_AFT=
    :LEFT_PLACES=1
    :RIGHT_PLACES=3
    :MUST_BE_LEADING
    :MUST_BE_TRAILING
    :MUST_BE_DECIMAL
    to kind of put things in before or after the “value” and to make them have leading zero, etc and the number of decimal places.
    The COLUMN= for each variable can be used to align the outputs. It essentially the number of spaces from the left side on where to write that info.
    (END QUOTE)
    I can elaborate on some of this if you still need help with it. Just let me know.
  1. Replies: 3
    Last Post: 10-05-2017, 02:03 PM
  2. VB editor
    By RicknBeachcrest in forum Screen Layouts, Post Processors & Misc
    Last Post: 07-04-2013, 05:56 PM
  3. MC X Editor
    By cijunet in forum Mastercam
    Last Post: 02-21-2008, 05:28 PM
  4. Editor
    By Okuma_ray in forum Uncategorised CAM Discussion
    Last Post: 01-07-2004, 02:30 PM
