586,036 active members*
4,331 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > turning without clamping the insert & how much effort when tightening an insert :)
    Jun 2015
    4154
    Hello good design should allow an insert to cut without actually clamping the insert on the holder
    in attach archive is a movie showing it : insert is put in place by hand, and it cuts @ 2000o/min x 1.5mm_radial_depth
    after cutting, turret raises and insert falls down
    tightening an insert on such a holder must not be done thinking that delivered torque must overcome the cutting forces, but only to keep the insert in place, not to fall because of gravity
    i use kyocera for turning, and in attached images you may see holder specification and clamp design
    the clamp mechanism uses a single screw to lock & drag the insert, thus there is a single section with effort inside the insert, and this effort is not great if normal tightening occurs
    about the main screw : if the hexagon of the main head is damaged, the hexagon at the opposite head may be used : no downtime
    when using holders from other producers, i noticed that insert and/or shim raises, when insert is clamped
    this does not mean that kyocera is the best i am not here to sell kyocera ...
    i only wanna say that kyocera turning holders look simple & robust, and kyocera printed catalogue has quality paper and really nice colors, not like the images from the pdf
    i hate when trees are cut to make catalogues and low quality furniture ... kindly !
    Jun 2015
    4154
    Re: turning without clamping the insert & how much effort when tightening an insert :
    with such tools, for roughing, on a recent setup, i machined clasic olc45 steel : cca17000cm3/wnmg_insert
    that is 17000/6=2850cm3/insert_edge i don't know if this is good or bad, but for me is ok
  1. Preferred choice of insert for Aluminum turning
    By buffaloguy in forum Material Machining Solutions
    Last Post: 04-01-2018, 03:25 PM
  2. Hard turning insert needed. ID grooving.
    By ChrisW in forum MetalWork Discussion
    Last Post: 12-03-2015, 08:28 PM
  3. help identifying turning insert
    By ndrew2505 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 05-03-2012, 01:18 PM
  4. Replies: 0
    Last Post: 11-30-2011, 06:31 PM
  5. insert grades for turning/drilling tungsten
    By claya in forum MetalWork Discussion
    Last Post: 06-28-2010, 07:15 PM
