588,528 active members*
6,676 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Taig 2019CR ER16 CNC Mill Motor Intermittent Start Up Issue
Results 1 to 7 of 7
    Sep 2006
    17
    I have about a 10 year old Taig 2019CR ER16 CNC Mill that I use for engraving text. After running it a while yesterday, the motor stopped and started intermittently. I tapped on the housing and the motor started up and ran for about an hour, then finally stopped again and would not come back on. This morning it came back on without issue. I know startup capacitors and relays go bad. Is anyone familiar with this issue?
    Attachment 366744
    Attachment 366746
    Attachment 366748
    Attachment 366750
    John
    Apr 2004
    5761
    Re: Taig 2019CR ER16 CNC Mill Motor Intermittent Start Up Issue
    Capacitors give the motor a boost on startup, but aren't necessary for the motor to continue running. Relays turn it on and off, but I doubt a bad relay would cause it to run intermittently. I'd suspect a loose wiring connection first off, but if that's not the problem, you might have worn something out in the motor over all those years.
    Andrew Werby
    Website
    Jun 2011
    69
    I would check the power cable to your motor.
    The combination of vibration, weight of the cable, and the movement of the cable, can cause the wires to break as it enters the motor!!
    This why I put a strain relief on my power cable...
    Stuart
    Apr 2005
    1268
    Also, since it has thermal protection, check it for excessive heat. How? I'd touch it. Maybe some other Taig owners can give you a hint of how hot they usually get.
    Hope this helps.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Sep 2006
    17
    I powered the motor this morning and wiggled the power cable and it remained running. The power cable is also under no strain.
    I am thinking it could be thermal related. I ran the unit way more than usual the day it failed and it may of over-heated.
    Sep 2006
    17
    Quote Originally Posted by sclelectronics View Post
    Stuart
    sclelectronics,
    I think you may be correct. Today I decided to power up the Taig and the motor would not start. I began to barely move the power cable and it powered up.
    The following video is about as exciting as watching paint dry, but it clearly looks like a loose connection or cold solder joint may be the culprit inside the motor housing.
    https://youtu.be/tnWWlZh3KA4
    Jun 2011
    69
    Glad you isolated your problem...
    In my motor, the power cord is not soldered!!
    They use wirenuts, then they are wiretied to the windings.
    So I think at least one of the wires in the power cable broke at the strain relief grommet....
    I have seen this many time in different machines.
    The cause is high vibration combined with the weight of the cord.
    All this stress is then focused where the power cable enters the motor housing..
    hth,
    Stuart
  1. New Taig 2019CR-ER - tramming/setup question
    By LaserImage in forum Taig Mills / Lathes
    Last Post: 12-14-2016, 05:19 PM
  2. Ordered a Taig 2019CR-ER Today
    By B-RAD in forum Taig Mills / Lathes
    Last Post: 09-14-2012, 11:21 PM
  3. Taig ER16 motor selection
    By AK_Five-O in forum Benchtop Machines
    Last Post: 01-29-2011, 07:25 PM
  4. Taig 2019CR with Mach 3 - help
    By tthompson in forum Taig Mills / Lathes
    Last Post: 10-28-2009, 06:56 PM
  5. Drill chuck options for a taig mill (ER16)?
    By japroach in forum Taig Mills / Lathes
    Last Post: 12-24-2008, 01:23 AM
