603,359 active members*
4,683 visitors online*
    Sep 2012
    7
    Kollmorgen S603
    Does anyone know the circuit design for supplying power to the IGBT driver stages?
    I seem to be missing the power.....I get 0V across the gates of all the stages to and bottom. I was expecting about -5V to -10V. I cannot trace the tracks because of the PCB.
    Has anyone drawn the circuit out......I've tried with limited success!
    Rich in the UK
    Dec 2017
    Re: Kollmorgen S603
    HI ! Rich
    I am AMIT PATEL from INDIA running my own workshop ,dealing in component level repairs from last 28 years , now involved Mainly in KOLLMORGEN servo drives repairs. I have handle many such drive in 600 series i.e. 601 , 603 ,606,610 620, 640 & S748.
    About the drive you need to check first whether DC 300+ is getting generated from 3 phase given, next that 300v DC is reaching to IGBT , Enable the drive with all necessary hardware etc. connected , then.... you can run the motor connected. If there is any problem you need to trace U V W circuit problems near IGBT on component level . I can repair it for you or in the extreme case provide you entire drive at a reasonable price.
    Apr 2018
    5
    Re: Kollmorgen S603
    I was looking for the same thing all around the web, i have an almost clean PCB board but is still hard to trace connections due to multi layer layout
    Quote Originally Posted by richmmm View Post
    Rich in the UK
    Apr 2018
    5
    Re: Kollmorgen S603
    X ray could do the job
  1. Kollmorgen S600 - Need Help
    By tomx in forum Servo Motors / Drives
    Last Post: 05-06-2018, 02:01 AM
  2. Kollmorgen AKD
    By banksviolette in forum Servo Motors / Drives
    Last Post: 06-26-2012, 12:30 AM
  3. vsd and kollmorgen servodisc
    By tomekscnc in forum CNC Machine Related Electronics
    Last Post: 03-09-2012, 08:13 PM
