586,067 active members*
4,901 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Request for foam-cutting bids
    Hi everybody,
    I'm doing the 3D work for someone who is prototyping an aircraft at RC scale. The fuselage I need to have machined from 1 lb. foam is about 6' 2" min length, and very simple in shape. (not looking for a Class A finish here) So, to those of you who can machine such parts, what would you expect the machining cost to be? (I can supply the file in STL or STP format.) Ideally, we'd like to do this work in the next couple of weeks. Let me know... Thanks!
    The plan is to cut two (left and right) fuselage halves. Each fuselage half is 6 ft. long, 14 inches tall, and 7 inches wide.
    Re: Request for foam-cutting bids
    Thanks to those who had a look here. This request is now filled, so this thread can be ignored or deleted.
  1. I need some bids on lathe work
    By Strip in forum Tormach Slant Lathe
    Last Post: 07-03-2015, 02:19 AM
  2. RCH2030 CNC Cutting machines /Chinese cutting machine for foam
    By ROCTECH-Vicky in forum Roctech CNC Routers
    Last Post: 12-25-2014, 07:58 AM
  3. Looking for bids for small machining job.
    By cr8zy1van in forum Employment Opportunity
    Last Post: 09-07-2011, 08:24 PM
  4. Laser/Waterjet Cutting - Quote Request
    By wwendorf in forum Employment Opportunity
    Last Post: 03-27-2008, 08:06 PM
  5. other places for RFQ/bids for work, etc.?
    By theshooter in forum Employment Opportunity
    Last Post: 02-09-2007, 05:08 PM
