586,112 active members*
3,081 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Aspire poor stl quality
    Aug 2014
    Hello,
    I import a stl file but the quality is very low. If I cut and import a piece from the stl file it gets better quality. 140 cm x 60 cm stl file on the right. 30 x 30 cm on the left. Why is this happening?
    Thank you
    Re: Aspire poor stl quality
    Because Aspire has a fixed, limited resolution, the larger the model is, the poorer the resolution will be.
    Make sure you use the highest resolution, by holding the Shift key when you start a new job, which gives you two higher resolution options.
    Aug 2014
    I am sure "Very High (7 x Slower)" And toolpath prewiev is Maximum. It makes sense that you first said. Thank you
    Very high is not the highest.
    There's also:
    Extremely High (20x Slower)
    and
    Maximum (50x Slower).
    To get these, you need to hold the Shift key when you click on the "New File" icon.
  1. Poor Cut Quality
    By JerseyBill in forum Hypertherm Plasma
    Last Post: 05-11-2012, 11:43 PM
  2. Poor quality finish
    By NylonAdmiral in forum MetalWork Discussion
    Last Post: 04-27-2012, 06:05 PM
  3. Poor cut quality
    By NorthridgeFab in forum PlasmaCam
    Last Post: 12-18-2011, 07:14 PM
  4. 3/16 Aluminum - POOR CUT QUALITY
    By zeoncomp in forum Waterjet General Topics
    Last Post: 08-01-2010, 05:10 PM
  5. tri-power poor quality
    By digitalmdj in forum Shopmaster/Shoptask
    Last Post: 12-02-2007, 01:45 AM
