603,919 active members*
3,448 visitors online*
Thread: VFD failure
Results 1 to 10 of 10
    Jul 2005
    48
    VFD failure
    How many vfd failures have there been. Mine just died after less than 6 months. Tormach is saying that they are rare to fail. I'm trying to decide if I should buy a spare
    Sent from my SM-G955U using Tapatalk
    Aug 2013
    980
    I bet it's rare. You are the first I've heard of.
    QUOTE=dbunyip;2079616]How many vfd failures have there been. Mine just died after less than 6 months. Tormach is saying that they are rare to fail. I'm trying to decide if I should buy a spare
    Sent from my SM-G955U using Tapatalk[/QUOTE]
    Nov 2011
    26
    Re: VFD failure
    Mine failed December 8th. Less than 4 months old. Heard of one other besides yours.
    Jun 2016
    184
    Re: VFD failure
    Mine failed too on very limited use. It does not appear they are rare to fail...
    Aug 2011
    61
    Re: VFD failure
    Had 2 fail on me already. Pcnc 440.
    15362
    Re: VFD failure
    With all these VFD fails I would think that this is a VFD programing problem, does anyone have a Breaking resistor, if not you most likely need it, this helps with how your spindle motor slows down, if it slows down too fast, you can easy damage the VFD Drive when you don't have a Breaking Resistor fitted
    Mactec54
    Jul 2004
    1424
    Re: VFD failure
    Quote Originally Posted by nutzilla View Post
    Important to be precise which machine we are talking about.
    Both the 770 and 1100 have an industrial Emerson VFD, which I believe has a low failure rate.
    The 440 has a BLDC motor controller. BLDC controllers have been problematic devices for a lot of small mills in the past, and I don't know where Tormach is sourcing them from. Anyone got a a picture of the device handy, maybe model name?
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Jul 2005
    48
    Re: VFD failure
    They defiantly changed something on my new one. It has a noticeable loss in power vs the first one.
    Jul 2004
    1424
    Re: VFD failure
    Quote Originally Posted by dbunyip View Post
    Might just be they derated the power in the controller to avoid future burn-up. Bummer, regardless. BLDC controllers seem expensive to do right, and cheap to do wrong.
    Tim
    Re: VFD failure
    I've made a little over 700 parts in the past year with my 1100 and I haven't had any issues other than a lose wire and the normal leaky stand issue.
  1. T2 Transformer failure
    By moonman5 in forum Bridgeport / Hardinge Mills
    Last Post: 09-27-2012, 04:52 PM
  2. MDI / RAP failure
    By s&swelding in forum Cincinnati CNC
    Last Post: 04-30-2010, 07:24 PM
  3. VB System Failure??
    By kbillan in forum Machines running Mach Software
    Last Post: 11-20-2008, 01:01 AM
  4. x axis failure
    By Legion99999 in forum Syil Products
    Last Post: 10-26-2007, 08:16 AM
  5. Having a CRT failure on a ulti 2 KM-3
    By godspeedbear in forum HURCO
    Last Post: 08-27-2007, 11:57 PM
