603,960 active members*
1,705 visitors online*
Results 1 to 11 of 11
Hybrid View
oldraven Problem with G43 command. 08-14-2017, 01:43 PM
mactec54 Re: Problem with G43 command. 08-14-2017, 08:48 PM
A1CNC Re: Problem with G43 command. 08-16-2017, 05:35 AM
oldraven Re: Problem with G43 command. 08-16-2017, 08:39 AM
mactec54 Re: Problem with G43 command. 08-16-2017, 01:17 PM
A1CNC Re: Problem with G43 command. 08-16-2017, 01:25 PM
oldraven Re: Problem with G43 command. 08-16-2017, 02:09 PM
mactec54 Re: Problem with G43 command. 08-16-2017, 04:29 PM
oldraven Re: Problem with G43 command. 08-16-2017, 04:47 PM
    Jan 2007
    78
    Hello all,
    Lately I have a problem with a line of code with the G43.
    Line N06
    N04 T01 M06
    N05 S1000 M03
    N06 G90 G54 X-38. Y22.
    N07 G43 H01 Z25.4 M08
    When my mill hits N06 the downward motion of the Z-axis is very slow, crawl speed.
    The Z DRO counts down normally.
    I encountered this in MDI mode if I forgot to enter a G00 before entering an axis move.
    The axis called crawled to its position too , very slowly.
    Here are the lines relevant in the postprocessor BC_3xMill.MillPst
    n,rapid_move,absolute_coord,work_coord,force_x,xr, force_y,yr,p_rot, s_rot,s,spindle_on
    n,rapid_move,length_offset,d_offset,zr,coolant_on
    machining_mode
    One sees the rapid_move instruction in the two lines, but there is no G00 in the code lines. ??
    Furthermore I use the UC100 USB motion controller
    When I used the Smoothstepper I did not have this.
    I abandoned the Smoothstepper as it did not do backlash compensation.
    Any insight ?
    15362
    Quote Originally Posted by oldraven View Post
    Hello all,
    Line N06
    N04 T01 M06
    N05 S1000 M03
    machining_mode
    Any insight ?
    Try it like this, this is the most simple format
    N04 T01 M06
    N05 M8
    N06 G54
    N07 S1000 M03
    N08 G90G0 X-38. Y22.
    N09 G43 H01 Z25.4 M08
    Mactec54
    Jul 2009
    219
    You Could do what I did, Just hard code it in.
    n,"G0",absolute_coord,work_coord,force_x,xr,force_y,yr,p _rot, s_rot,s,spindle_on
    machining_mode
    Jan 2007
    78
    Quote Originally Posted by A1CNC View Post
    n,"G0",absolute_coord,work_coord,force_x,xr,force_ y,yr,p_rot, s_rot,s,spindle_on
    machining_mode
    I already did that.
    But I made a mistake , the problem is line N07 the G43 code.
    N07 G00 G43 H01 Z25.4 M08
    Did not work. The G43 still makes the head crawl downwards.
    I'll try Mactec54 's code today.
    15362
    I already did that.
    G0 should not be used on the same line as a G43
    Mactec54
    Jul 2009
    219
    Well if it did not work with the change I posted and the head still creeps down 2 things are possible. (1) The control might need to see a rapid command on every line though not totally likely. (2) the section of the post you are working on might not actually be what is controlling the lines you need to change.
    Have you tried turning the debug on? This will tell you exactly what section of the post is active.
    So if you want the G0) in the line before the G43 try this,
    n,"G00",
    n,length_offset,d_offset,zr,coolant_on
    machining_mode
    It should look like this
    N04 T01 M06
    N05 M8
    N06 G54
    N07 S1000 M03
    N09 G00
    N10 G43 H01 Z25.4 M08
    There could be other things that need to be updated in that post also to get it to work how you want it to, I just noticed on line 14 it is different than my post for a different machine. Can you also add the section number for the section of the post you have here? It will make it easier to help fix this.
    Jan 2007
    78
    Hi guys,
    I think that I have found what is going on.
    Since a couple of weeks I changed the Smoothstepper for an UC100 USB to PP.
    This to activate the Mach3 backlash control.
    Then the problem with stalling on G43 appeared.
    I have tried your advise and changed the Postprocessor.
    That did not help much. Sometimes the G43 line worked with no problem, but the second or third time the Z down stalled again.
    That got me thinking, put the Smoothstepper back in or disable the backlash control.
    As disabling the backlash was easy and quickest I did just that.
    The G43 problem was gone.
    Back to the standard BC_3x_mill post and that worked too, flawlessly .
    The backlash control made the axis jump a bit, so I suspect a spike from the stepper motor might have introduced the G43 fault.
    I will replace the Lovejoy L-50 couplings as the backlash is too much.
    Thanks for thinking with me,
    Jos Raven
    Holland
    Jos Raven PA0AMX
    15362
    Hi guys,
    Jos Raven
    Holland
    Jos Raven PA0AMX
    Are yes backlash, will do this you did not tell us the whole story, your code was not correct also, but one thing Mach3 is good at is accepting almost anything you through at it as far as code format
    There are a few that have figured out how to use the backlash, but for most it fails badly
    Mactec54
    Jan 2007
    78
    The problem at the G43 is, that this line of code tells the Z-axis to move.
    The Z-axis is driven by a hefty NEMA43 stepper motor. So I imagine that this motor produces a big spike that possible is picked up by the USB cable.
    15362
    If you are using a USB cable, it has to be a high quality cable which will protect the signals on the cable, you should also have shielded cables for your motors, with correctly terminated shields, and your motor won't interfere with any sensitive signal's
    Mactec54
  1. Replies: 0
    Last Post: 06-04-2013, 07:39 AM
  2. Bootup Problem (Command Prompt)
    By genebaq in forum Milltronics
    Last Post: 10-30-2012, 07:57 AM
  3. Fanuc 6T G01 command problem
    By hell_pk in forum Fanuc
    Last Post: 06-24-2011, 09:07 AM
  4. problem with ,C command
    By cncozz in forum G-Code Programing
    Last Post: 07-02-2008, 05:23 PM
  5. Problem with the G70 command
    By markus314 in forum G-Code Programing
    Last Post: 06-23-2008, 07:25 PM
