586,076 active members*
3,802 visitors online*
    Jun 2014
    6
    To wire a new power supply
    Hi all,
    I have just received a new power supply for my 50w Chinese Laser cutter. It appears that the terminals are setup slightly different.
    I have attached a diagram of my original layout and how I intend to wire my new power supply.
    I would be grateful if you more knowledge folk could spare a moment to take a look to see if it looks ok.
    Thanks in advance
    James
    Jun 2014
    6
    Re: To wire a new power supply
    UPDATE: Since I didn't get a reply, I went ahead and tested this setup anyway.
    Everything seems to be ok with this setup but now I just hear a hissing from the laser tube when I fire a test pulse but the laser doesn't fire. :/
    I'll make a new thread on this and hopefully people can shed some light on it.
    J.
  1. How Do I Wire This Power Supply?
    By herring_fish in forum CNC Machine Related Electronics
    Last Post: 04-06-2012, 03:05 PM
  2. FLA-100 - 48 Power Supply Wire Gauge
    By Darylb in forum DIY CNC Router Table Machines
    Last Post: 11-18-2011, 01:41 AM
  3. power supply for 2mm hot wire
    By aaabeee in forum CNC Wire Foam Cutter Machines
    Last Post: 09-05-2011, 04:04 PM
  4. My New Power Supply for Wire
    By indycraft in forum CNC Wire Foam Cutter Machines
    Last Post: 05-21-2011, 07:23 PM
  5. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
