586,102 active members*
2,485 visitors online*
IndustryArena Forum > CNC Electronics > DeskCNC Controller Board > Setting up 0,0 offset from laser crosshair
    Jun 2017
    369
    I'm trying to set up my new to me router that the previous owner had installed a laser crosshair to use to easily set 0,0 home start position. My question is where in DeskCNC do I set this up?
    Thanks in advance
    Apr 2007
    60
    Re: Setting up 0,0 offset from laser crosshair
    Gary, how did this crosshair work? Does it trigger a switch, or simply shine a dot onto a position?
    If it is a switch per axis, they need to be wired into the card. See the attached .pdf file. You then set up the DeskCNC homing under the Machine Setup Configuration tabs. Tick Home using Lim in the DeskCNC Setup tab, and configure your parameters in the Home Script tab. See the typical settings in the attached txt file.
    You probably just jog the machine until the laser is where you want it, then zero the X and Y axis. I doubt that there's anything in DeskCNC for the crosshair.
    Jun 2017
    369
    The original owner can't remember where it is but he said it is in there.
  1. How setting tools and setting offset
    By John246 in forum Sharp CNC
    Last Post: 04-09-2016, 08:31 PM
  2. Need help setting offset with probe
    By mioduz in forum Haas Mills
    Last Post: 04-18-2015, 01:21 AM
  3. big-tex screen set laser crosshair setup HELP
    By jbunes in forum Mach Wizards, Macros, & Addons
    Last Post: 02-05-2015, 06:34 AM
  4. Z offset setting
    By dcutler35 in forum Uncategorised MetalWorking Machines
    Last Post: 05-25-2012, 02:08 PM
  5. setting work offset(G54 etc)
    By dek in forum RFQ Feedback
    Last Post: 04-07-2010, 03:17 AM
