603,900 active members*
2,284 visitors online*
IndustryArena Forum > CAM Software > SheetCam > using the wrong post processor?
    Jul 2017
    41
    i could use some assistance in helping me fix the issues im experiencing, i think mabye in settings in sheetcam itself, or the post processor im using?
    so i have been getting what I think are decent cuts out of my cnc table using the PM 45xp, but im having a few issues I dont know how to correct. and a few questions. im
    cutting 12ga stainless using powermax manual specs to the T .08 pierce, .02 cut height 45 amps, feed rate is 110 ipm
    my trouble is on some i would say 50/50 any inside details in my part it starts the cut and cuts the shape weather its a circle or whatever fine but it doesnt complete the cut, leaving 1/16" plus or minus of metal that in most instances is very hard to get out. i attached some pictures. and smaller holes i would say 1/4 or so smaller the hole is very jagged and not nice looking like I have seen on alot of completed parts.
    is there a reason why some inside features would be fully cut and some left unfinished, in the G code using mach 3 and sheeetcam you can clearly see the details are there and its suppose to cut all the way through. any help is much appreciated.
    im using the post processor MAch 3 with flame +THC, in which im cutting without my thc on at the moment.
    here are the pictures. the last fish picture and inside the N and E on the name is what im talking about inside features arent being finished. and the backside of the cut seems to be thinner than the front.
    Attached Thumbnails Attached Thumbnails 20170828_145123.jpg   20170828_145044.jpg   20170828_145114.jpg   20170827_225348.jpg
    Apr 2003
    540
    Re: using the wrong post processor?
    It may not be the problem, but check your pierce delay. If it's too short the machine is moving before the pierce is complete which will result in the same issue you are having.
    Using a longer pierce delay may help. I also can't tell if you are using lead-in's and outs? If not, using them may also help avoid the pierce points affecting your cut edges.
  1. Replies: 1
    Last Post: 01-02-2021, 11:05 PM
  2. Do you know what is wrong with my post?
    By Fanny-Roctech in forum Roctech CNC Routers
    Last Post: 05-30-2015, 08:21 AM
  3. post processor producing wrong code
    By nigel2000 in forum EdgeCam
    Last Post: 01-29-2015, 08:05 PM
  4. wrong machine definition , post processor issue ??
    By luckyyyyyy in forum Mastercam
    Last Post: 02-10-2010, 11:10 AM
