586,103 active members*
3,185 visitors online*
Thread: alphacam v5
    Apr 2013
    alphacam v5
    HOLA... PREGUNTO COMO HAGO EN EL ALPHACAM V5, PARA QUE (EJEMPLO) EN UN ARCHIVO QUE ES UN CIRCULO, NO EMPIECE A CORTAR EN LA MISMA LINEA DEL CIRCULO, SINO , QUE EMPIECE DESDE EL CENTRO O DESDE AFUERA ? TENGO UN PANTOGRAFO PARA METAL CON UN PLASMA THERMAL DYMAMICS.... SALUDOS
    Apr 2010
    89
    Re: alphacam v5
    Goto Machine --> Tool Directions
    Select CW or CCW for Directions
    Select Outside, Inside, Left or Right for Side
    Then click on the Closed geometries you want to alter the tool cutting side.
    From memory I don't think open geometries can have the tool cutting side altered from centre (default ) in V5.
    Regards,
  1. Alphacam
    By Maroslav4 in forum Alphacam
    Last Post: 11-08-2015, 11:31 PM
  2. Alphacam to a Rye CNC
    By Trell in forum Alphacam
    Last Post: 09-09-2014, 01:20 AM
  3. alphacam vba
    By zx6 in forum Uncategorised CAM Discussion
    Last Post: 04-01-2014, 08:18 PM
  4. AlphaCAM 00 and AlphaCAM V5 - same postprocessor
    By Ziyan in forum CNC Machining Centers
    Last Post: 10-10-2011, 12:59 AM
  5. alphacam 3d
    By shab_108 in forum Uncategorised CAM Discussion
    Last Post: 11-28-2008, 08:23 AM
