586,036 active members*
3,917 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Alternatives to the original Taig spindle motor?
Page 1 of 2 12
Results 1 to 20 of 25
    May 2006
    309
    Are there any good alternatives with adjustable speed to the original 250 W Taig spindle motor?
    Nov 2009
    4415
    Re: Alternatives to the original Taig spindle motor?
    ebay
    A lazy man does it twice.
    May 2006
    309
    Quote Originally Posted by Fastest1 View Post
    ebay
    I´ve understood that not all of the spindles that are sold on ebay are good. I need to know which of them I have to buy.
    Apr 2004
    5737
    What did you want to cut? The Chinese spindles on Ebay generally go quite fast, which is fine for wood and plastics, but not so good for metals. They are way too fast to use as a motor on the standard Taig; the bearings aren't rated for more than 10k rpm. But the standard Taig motor won't work well on 50hz current, which you use there. I generally advise European clients to purchase a Taig without the motor, and source one locally. You'd want one with close to the same specs: totally enclosed, fan-cooled, continuous duty, 3450 rpm, and 1/4 hp or better induction motor. That shouldn't be too hard to find. But if you really want variable speed, what about something like the Sherline DC motor, which comes with a speed controller: 33050 DC Motor and Speed Control Units — Sherline Products ?
    Andrew Werby
    Website
    May 2006
    309
    Quote Originally Posted by awerby View Post
    I´m carving and engraving in wood, so I was looking for a spindle with easier speed regulation than the belt moving on Taig and with the same speed range. I have used the original Taig now in several years on 50Hz without any other problems than some sparkling noise issues.
    Apr 2004
    5737
    People have repurposed treadmill motors to run their spindles; the trick is to find one that's light enough. If you use one of those Chinese spindles, the speed range won't be the same. They give you a top speed that's about twice as fast, but the lowest speed of that spindle will be close to the top speed with the regular motor. Go much slower, and the torque falls away to nothing, while the fan stops providing any cooling. But if your regular motor works okay for you, save that for jobs that need slow speeds, and mount a dovetail to the back of the high-speed spindle so you can swap it in easily when you need to spin fast.
    Andrew Werby
    Website
    Jun 2011
    68
    I am playing with one of the BLDC sewing machine motors....but this from GlockCNC....850w
    Also I am using one of their MT3 HD Spindles.....
    Stuart
    Sep 2009
    38
    Deepgroove1 has spindle motor setup. Consew makes a brushless servo motor for controller that are all over ebay. I have been using a treadmill motor with a kb controller running with the taig step pulleys. I have a consew motor sitting on the bench it has much more torque then the treadmill, but the treadmill motor has a higher rpm. Not that it is recommended but I can spin the spindle at 18000 with the treadmill motor, I usually keep below 10,000 rpm.
    tread mill motor
    consew motor
    if you need more power
    deepgroove1
    Jan 2017
    4
    Quote Originally Posted by sclelectronics View Post
    Stuart
    How is that spindle working out?
    Jun 2011
    68
    Quote Originally Posted by theSSshow View Post
    Loving it!!
    I am enjoying using the TTS tooling system...
    I am currently working on controlling Mach3 Motor control.
    Using a C69 control board connected to my ESS 2nd port .
    Now I am working how to get rpm index pulse circuit......
    Stuart
    Jul 2011
    124
    Stuart
    I just got the same motor. How can I bypass the foot pedal? Or any idea on what size pot I would need? I can 3d print a box I think
    If I hold the foot pedal open and flip the switch the motor doesn't spin, so maybe a fail safe. So I'm thinking wiring it closed won't work right off the bat
    Jun 2011
    68
    I need to find the pot that came with my motor and I will measure the resistance.
    The motor does have a built-in failsafe!!
    So when the power is turned on, the pot/pedal must be in the "Off" position.
    Then the motor will "Arm " itself. So now when you adjust the pedal/pot the motor will start to turn.
    Stuart
    Jun 2011
    68
    Just found the Speed adjusting pot.....
    It is a 25k ohm......
    Here is a photo of how it is wired....
    Stuart
    May 2006
    309
    What is the price of this sewing machine motor? I found another with 400W engine for Euro 93.-
    https://www.banggood.com/220V-Brushl...r_warehouse=CN
    yep/ i have 2 taig lathes with Aurora wjv-55 (550W) Brushless Servo Motors for Industrial Sewing Machine. Very good/ This foto with previous same motor - jati 550
    Attachment 383820
    Jul 2011
    124
    Quote Originally Posted by Alout View Post
    Attachment 383820
    I heard there is a way to make them spin faster on the controller. Mine goes up to 4200rpm, do you know how to make it go faster?
    Yes, something like that, too. but the specific schemes not caught. I think you can just the pulley on the spindle to change for reduction 1:1. Or 1:2. pulley is very cheap (3-5 usd). Auroras max rpm default 4500.
    Aug 2016
    37
    You can adjust the upper speed limit of the Consew motor through the menu system. Just depend on which version you are using as to the process. Mine has the four digit, four button panel. Once you get the top speed showing on the menu, I just push the up arrow which adjusts it up to 7000 RPM. But I've only been about to achieve 6500 RPM consistently. Using a quadrature encoder for feedback to UCCNC via a UC300ETH which gives full PID control over the spindle. It nicely holds within 10 RPM and ramps up when taking deep cuts. Pics and vids of my setup, how I setup software control and the encoder are on the Taig Facebook Group.
    May 2006
    309
    What about the 900W motor in Kenwood chef Kitchen machine. Are there anybody here who know how much rpm. they have on fastest speed? I believe these motors must be easier to obtain than sewing machine motors..
    Aug 2016
    37
    Quote Originally Posted by jaru-eri View Post
    How easy is that - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Page 1 of 2 12
  1. Original Emco120P Spindle DC motor under Field Waekening Control: Done!
    By darenfs in forum Vertical Mill, Lathe Project Log
    Last Post: 03-10-2016, 12:35 PM
  2. Replies: 2
    Last Post: 12-21-2015, 11:31 PM
  3. Spindle Motor for Taig ER16 Spindle
    By jupdyke in forum Taig Mills / Lathes
    Last Post: 04-15-2011, 05:33 PM
  4. Keling servo as Taig spindle motor replacement?
    By Hirudin in forum Taig Mills / Lathes
    Last Post: 08-18-2009, 11:41 AM
  5. High Speed Spindle for Taig - Brushless Motor?
    By GammaWill in forum Taig Mills / Lathes
    Last Post: 03-29-2007, 09:43 AM
