586,071 active members*
3,801 visitors online*
    Sep 2017
    5
    Which program to use
    I am completely new in this area of expertise and have a question.
    I have looked through different recommendations of which programs to use for creating a sketch and then creating the cutting path (again completely new at this so the terminology might be off). So far I have settled on either Sketchup or Fusion 360. Since I have no experience in either 3d modelling or Cam I guess I might as well earn it proper and go the deep route i.e. Fusion360.
    My question is then, is this a good choice? Will it work with the MicroMill, should I start with a simpler tool and so on?
    Best Regards
    Jan Svensson eagerly awaiting my MicroMill
    Sep 2017
    Re: Which program to use
    I'd recommend Fusion 360 since there are lot of Youtube tutorials available (on how to use the program itself, not for use with the MicroMill - but the exported g-code works with Grbl Panel)
    Sep 2017
    5
    Thanks for the answer, I suspected as much and have started watching the tutorials on their site. It is really good to know that the g-code works with Grbl Panel! Thanks again
    Sep 2017
    for a quick test I'd recommend Easel - see the sticky "first project" thread above!
    Sep 2017
    5
    Doh, it even mentions Fusion 360 in that thread. I should have read it one more time. Thanks again for your patience and help.
  1. Steps to develop VB program to read CNC (G-code) program.
    By BhushanM01 in forum Visual Basic
    Last Post: 12-12-2017, 07:57 PM
  2. Replies: 1
    Last Post: 02-11-2015, 02:38 AM
  3. Replies: 1
    Last Post: 09-18-2014, 12:29 PM
  4. Replies: 4
    Last Post: 03-06-2013, 07:56 PM
  5. Replies: 0
    Last Post: 12-27-2010, 09:55 AM
