586,113 active members*
3,081 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 10TE-F with main board error F
Results 1 to 7 of 7
    May 2010
    14
    Hello, not sure if anyone can help. We have a Hitachi Seiki HT20 with Fanuc 10TE-F control.
    There's no life at all on the screen. When we press the power-on button the main contactor comes on but the screen doesn't light. Around the back, the main CPU board shows an 'F'. All lights are green in the cnc cabinet, I've measured the psu test pins on the cpu and they're all spot on.
    A quick google brings up the usual resellers of pcbs that will 'cure' an 'F' fault...
    The machine has been idle for a few months but came on ok and did half a day's work before it turned itself off.
    Aug 2007
    793
    Re: Fanuc 10TE-F with main board error F
    check optic cable
    couple times faulty position module PT01A was the reason
    Dec 2009
    539
    Hello
    check these items
    Connection failure of connection unit or I/O cards D1 ~ D3.
    Check the optical fiber cable connection of these units and connectors.
    Replace master PCB, connection unit, I/O cards D1~D3, or optical fiber cable.
    These are standard issues for an F alarm on a 10T
    John
    Optical Interface ( I/O ~ Master PCB ).IF01A PCB plugged into wrong slot in I/O rack.
    Failed I/O module in I/O base unit.
    May 2010
    14
    Thanks folks. We have the service manual but no spare boards to swap. We tried the optical cables, no luck. The boss has decided to send the lathe for scrap rather than spend any more money on it; it had to have a new VDU last year so it's a case of drawing a line under its little expenses!
    Feb 2012
    126
    Are you going to salvage any parts from it?
    I would be interested in a couple cards.
    Aug 2007
    793
    Quote Originally Posted by superstardeejay View Post
    is there any PT01A module, it looks like yellow box
    May 2010
    14
    Before scrapping the machine we had an engineer take a quick look and swapping the power supply card in the spindle-drive cabinet cleared the fault. So all working now with a service exchange card :wave:
  1. FANUC 10TE RAM problem
    By guhl in forum Fanuc
    Last Post: 12-20-2019, 05:41 PM
  2. Replies: 0
    Last Post: 02-01-2017, 03:44 PM
  3. Fanuc 10TE-F manuals
    By Eagleeye in forum Community Club House
    Last Post: 03-17-2012, 08:25 AM
  4. Fanuc 18t-b main board plug in cards
    By amtekinc in forum Fanuc
    Last Post: 03-23-2011, 07:15 AM
  5. Fanuc 10TE-F
    By NigelM in forum Community Club House
    Last Post: 07-13-2010, 12:13 PM
