586,096 active members*
3,677 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Do lathe headstock spindle bores require line boring?
    Jun 2016
    8
    In all of the gingery lathe build logs I've read, a temporary headstock is constructed for the sole purpose of line boring the permanent headstock.
    Assuming everything is correctly indicated and the machine is properly trammed, can't it be done using more common drilling and boring operations on a lathe, mill or drill press?
    Sent from my iPad using Tapatalk
    Jul 2007
    1602
    Re: Do lathe headstock spindle bores require line boring?
    The headstock is line bored to ensure that the spindle is perfectly aligned to the bed. It is the simplest and fastest way get it accurately aligned and does not require the use of indicators etc... If you machine the bore separately then you need to align it to the bed in multiple axes. That is not an easy task and you would probably not get it as well aligned. It is actually less work to build the temporary headstock than to try to align it otherwise.
    bob
    Jun 2016
    8
    Quote Originally Posted by rowbare View Post
    bob
    Thanks. The reason I asked is because I have two 109 craftsman lathes in various states of repair. The spindle bores are way too small. I am contemplating on reboring one of them to support at least a 20mm MT1 spindle by using the other as a temporary headstock.
    The issue is how to mount the target headstock (the one being rebored) on the bed rails while allowing it to slide. Normally, to perform a line-bore, the target is mounted on a carriage. If I do this, it will offset the bore. I could clamp the target on its side, but it would be just as hard as not line boring at all.
    Any ideas?
  1. Choosing lathe headstock spindle for CNC build
    By RamenNoodles in forum Uncategorised MetalWorking Machines
    Last Post: 04-16-2023, 02:03 PM
  2. Replies: 0
    Last Post: 05-30-2016, 08:08 AM
  3. Replies: 0
    Last Post: 05-29-2016, 12:54 PM
  4. Replies: 0
    Last Post: 07-29-2014, 11:56 AM
  5. Mini lathe headstock for Spindle
    By rgillam in forum DIY CNC Router Table Machines
    Last Post: 05-24-2005, 01:59 AM
