586,094 active members*
3,989 visitors online*
IndustryArena Forum > MetalWorking Machines > Smithy > Smithy 1240 cnc questions
Page 1 of 3 123
Results 1 to 20 of 43
    Mar 2007
    8
    I am looking at buying a smithy 1240 cnc mill and have a couple questions. It will most likely be the full package with their controller as money is not a big issue.
    -Will it work alright with Mastercam ? Mastercam does have Fanuc posts but I am not sure if they are right for this controller. (It is the software I am familiar with). What type of Cad are others using with success?
    - Do people have alot of problems with stepper motors as opposed to servos? I plan on making a fair amount of parts off of jigs.
    _ Is there alot involved in getting one up and running after shipment? I am fairly knowledgeble in mechanics and have done machining for 20+ years.
    - Has anyone gotten one of their new 1240's with the belt drive and had the option of getting servos instead of steppers? I believe they had an older model with servos once.
    Thanks in advance for any response to this.
    Dec 2006
    839
    I dont think anyone has bought this new machine yet. But you might find someone that will know the anwsers to the softwear question. Might be better to call Smithy up & ask them the question on the softwear capatibility.
    I am afraid this setup is just to new for many to know much about it. Although there was a few that had bought to older machine. But there has been alot of changes made to the machine ( needed ones & some not so much). Like the new belt drive with VFD is a big improvment over the older gear headed machine ( or atleast should be). But droping the servos over stepper IMO was not a good thing, although steppers are nothing to be worried with, most machines do use them, unless its a factory CNC machine.
    Jess
    Mar 2007
    36
    Smile Re: steppers
    Hi Nupeswv,
    Smithycnc 1240 claims 1700 oz-in steppers for xyz.
    For a comparison, Tormach PCNC is 640 oz-in for xy and 1200 oz-in for z. Tormach claims the 1.5 hp spindle will stall, or the cutter will break before steps are lost.
    I think both machines are pretty good, lots of videos at Tormach site, only one that I know of for Smithycnc 1240, however the machine is newer so they probably need time to post.
    Tormach has ground ballscrews at P4, whereas, Smithycnc is P5 (are we going to grumble about .0003" difference? --a few of degrees of room temperature difference may negate .0003" anyway!!)
    Again, I believe both machines are worthy of purchase.
    Let us know what you decide on, we'd appreciate hearing how it goes for you!
    jmg
    Jun 2006
    2512
    The practical difference between the two is that with servos (closed loop)you can set your maximum feed rate closer to the limit of the system with less worry about lost steps. With steppers (open loop) you have to back off a bit on the maximum allowable feed rate in order to avoid the risk of lost steps and the ensuing crash. If maximum feed rate is of commercial value to you then go with closed loop. If it isn't a big issue then save some money and complication and go with open loop.
    My opinion is that if you think you need a closed loop system then you probably need a fully fledged "commercial" machining center.
    Just some thoughts from a novice.
    Phil
    Quote Originally Posted by nupeswv View Post
    Mar 2008
    I purchased the Smithy 1240 mill four months ago, so far it has been a good machine, I have been using mastercam to cut parts and so far it has worked fine. No problems with the stepper motors. I have had trouble with the X and Y travel proximity switches, in fact I am waiting on a replacement for the third failure now. Otherwise no other maor issues.
    Sep 2007
    16
    Hi - I got my 1240 Smithy mill in early Feb. and have been using it regularly since. I am a machine designer/prototyper and use it to make parts for the manufacturing machines I make. I have done UNMW (40 hrs.), 6061 aluminum ( 50 hrs.), and low carbon steel (20 hrs). The 1240 performs well once I figured out what it could handle. For the aluminum I was using a 1.25 in. diameter 3 flute cutter with al. inserts for a lot of material removal. 3000 rpm, 15 ipm, 0.080 doc. The inverter driven 3 phase motor works well but under heavy load the spline clearances on the spindle shaft seem to contribute to some chatter. The belt drive is a blessing. I use Mach 3 and have found that when I increase the feedrate during machining the rapid feedrate is increase by the same percentage. I have crashed a few times because it lost steps being unable to move at 2X the standard 75 ipm rapid. The big stepper motors seem to be able to do anything I have asked it to do without a problem so far. I did break a 3/8" cutter one time by driving it (spindle off) into my material, the X axis stepper didn't even seem to notice. I have done some holding jigs that were 24" X 24" by revolving them about a fixed center reference pin. They turned out nicely so I am quite pleased with limits of the machine. Whenever I have needed to call Smithy there has been a person there to talk to and they have answered my question well. As far as setting the unit up the biggest challenge for me was unloading that much weight out of my Sprinter van and then lifting it up so I could slide the Smithy stand under it in my low ceilinged shop. Both tasks were accomplished with a chain hoist and a little creative rigging. There is little or no mechanical challenge involved in the uncrating and setup.
    I use IronCad, Dolphin CAD/CAM (it has an IronCad addon that quickly send surfaces to the Cam software), CutViewer ( for cnc verification) and Mach 3 for machine control so I can't comment on you software questions.
    So far I feel like I spent my money wisely and feel very good about having the Smithy.
    Good Luck
    Gary
    Aug 2005
    132
    Hi Guys,
    I have been a bit worried about the purchase I got my boss in the US to do on a Smithy CNC 1240.
    Other than hardly any information on the net about them. Hardly anything on their site.
    And not a great deal of replys to emails.
    It makes me feel a bit better that you guys like your machine.
    Do you guys have any information on connecting the unit to the PC.
    eg Confirgurations etc.
    And any recomendations on setting up.
    I'd love to see some of the work you guys have done on the machine.
    Do you have any pictures at all?
    I'll be flying over to the US in a couple of weeks to set the unit up.
    Any help would be great.
    Cheers
    Rodney
    Feb 2008
    176
    The units come with some setup info, but you should be able to get them at Smithy as a pdf file upfront. The units are heavy.
    If I was in your position I would check the following parameters first: 1.angle between table and spindle in x and y direction. Do this with a dial indicator. 2.accuracy of the table and spindle movement. Do this with dial indicator and reference pieces. 3.adjust the physical reference pieces. The work cube set up in China might be far less than the machine has to offer. 4. Control functions incl. cooling.
    Hope that helps
    Aug 2005
    132
    Hi benji2505,
    Thanks for the info. I finally got the info I need from Smithy.
    They are suppose to dial the machine in before you get it.
    But I will check it all out. Ta.
    Rod
    Jul 2005
    151
    DMICHALS AND GSTUART,
    I'm thinking of stepping up to a larger mill- What type of spindle drive does the 12-40 have- is it installed in USA or China?
    How about the CNC- USA or China?
    Any opinions on the reliability of them?
    Sep 2007
    16
    More experience and pictures
    I like the spindle drive design on the 120. Its a 3 ph. motor directly driving the spindle using a toothed belt. The spindle itself easily drops out of the head by removing 3 screws. I took it out once and it appears substantial enough for the job and would be fairly simple to rebuild or ship back to Smithy to have them rebuild. The upper end of the spindle shaft is a spline and on my machine the clearance between this spline and the drive pulley it engages is greater than I would like. I can grab the milling cutter and rotate it back and forth and feel the spline moving in the pulley. I was having problems with chatter when using a 1.25" cutter (on aluminum) and I had to reduce feed and DOC to compensate. I have since stopped using the R8-ER40 collet adapter I was using for heavy cutting because the collet adapter extended the cutting tool almost 3" beyond the end of the spindle. I think that additional distance was causing a lot of flex at the cutter end. I now use 1-1/2", and 2" cutters with R8 shafts and the operation is much more rigid. I liked the ER40 collet because bit changes were quicker but for the heavy cutting it didn't pan out. All in all I am still happy with the machine. I have attached a few pictures (If I can get them loaded) to show some of what I have been doing. The black material is 3/4" thick UHMW and the others are of some Aluminum assembly jigs I made.
    PS. Upload is not working right now. Will persist.
    Jul 2005
    151
    Thanks-
    Is it USA or Chinese motor- I am pretty good at fixing anything mechanical that could go wrong, but 3 phase VFD is out of my league, so i would want to know its good stuff. On my 3 in 1 machine I have about 0.008" lash in the spline shaft which is expected for a low cost unit. Its ok with small end mills, but you can feel the lash when you use a fly cutter. Its odd that an expensive CNC machine would have that issue too.
    Feb 2008
    180
    Smithy seems nice but I would never choose it over a Tormach. I researched this for 6 months before buying a Tormach with confidence and let me tell you it came I set it up and started making parts with close tolerances with no problems at all. And their tooling system is very nice and works great. I run this machine pretty hard on SS alot. NO PROBLEMS AT ALL. But the smithy looks nice over priced and have herd that it does not come ready to run? Call Tormach and you will be happy with your purchase. Smithy has been around for a while it does not have the travel. Do your homework compare over and over until you are sure.
    Nov 2007
    277
    highspeedmazak You are talking about a more expensive machine and alot of people are not going to pay that much. They want a starter machine they can learn on. You are in the wrong forum trying to push a product out of their price range. Sell your product elsewhere.
    Aug 2005
    132
    What the hell are you on digitalmdj?
    Smithy 1240 CNC is the thread name and they are more expensive than a tormach. How do I know this?
    My boss bought one. I did the research and it had a bigger working cube than the tormach. So we got it.
    Personally with the sales support I got I think maybe I should of got another machine. 3 emails before I could even get a quote.
    And responces on questions weren't that great either.
    As far As know the smithy is ready to run when it arrives.
    I think you are thinking of the manual 1240 digitalmdj?
    Jun 2006
    2512
    Why does the 1240 CNC have splines on the spindle shaft.
    If it is meant to be free sliding then the splines have to have a little free play in order to prevent binding due to temperature variations, manufacturing tolerances etc.
    Phil
    Quote Originally Posted by GSSTUART View Post
    Jul 2005
    151
    I think the question is about the overall tolerances of the machines. The lower budget bench mills and 3 in one machines will have greater clearances on the splines because the tolerances of the machining of the pulleys and the quill may not be that close and require some looseness in the splines to prevent binding as the spindle moves up and down. You would reasonably expect that on a higher priced machine designed for production CNC use, the overall tolerances would be much tighter and allow a closer tolerance on the splines.
    Feb 2008
    176
    The spindle does not move in a smithy 1240CNC or a 1034CNC, the whole head moves. The splines are a historic heritage, the machine base used to be a Chinese manual milling machine with moving spindle. The Chinese company just kept the engineering. We had the same issue with the play in the spindle and we had Smithy replace the whole machine head, which they did with no mourning (and we got the tech-history of it). We did it because of a rattling noise that was caused by an unbalanced belt pulley, not because of the spindle play.
    To answer another question from earlier: the motor as well as the steppers are all chinese. The motor is rigid and good. The attached cooling fan is a little loud though, sometimes we wished it was controlled by a temperature control. The frequency controller for the motor comes from Korea.
    Jul 2005
    151
    Benji,
    Thanks for the info. Sounds like it is a work in progress machine and most likely there will be a new model coming out without the spline drive. Chinese motors with Korean controller makes me nervous- too many possibliities of political problems causing shortages. I think Tormach has the best choice in this size machine.
    Jun 2006
    2512
    Not sure I understand the political problem with Chinese motors and Korean controllers. A large portion of the Tormach is of Asia origin also. Many on the Zone build their machines from scratch so replacing the odd component from sources other than the OEM shouldn't stretch the imagination too much. I do agree on the spline issue though. It sounds like a totally unnecessary weak point. Makes you ask the question "what else".
    Phil
    Quote Originally Posted by fastlanecafe View Post
    Benji,
Page 1 of 3 123
  1. Smithy 3 in 1 ?
    By fyffe555 in forum Smithy
    Last Post: 12-29-2007, 03:26 PM
  2. Replies: 26
    Last Post: 02-25-2007, 10:35 PM
  3. new used smithy
    By john Lucas in forum Smithy
    Last Post: 11-16-2006, 09:50 AM
  4. Smithy to a CNC?
    By ishamon in forum Linear and Rotary Motion
    Last Post: 11-24-2005, 05:08 AM
  5. smithy 3n1 to cnc
    By kenlambert in forum Knee Vertical Mills
    Last Post: 02-05-2004, 09:24 PM
