603,785 active members*
17,756 visitors online*
IndustryArena Forum > CAM Software > CamWorks > edit the post to move the tool list after the program number
Results 1 to 10 of 10
    Oct 2009
    10
    How can I do this? right now my post outputs the tool list before the program. I need to list the tools after the start of the program.
    I am using this line in my Lib file
    :C: GETTOOLS(2,OUTPUT_TOOL_LIST)
    and this section in the src file
    :SECTION=OUTPUT_TOOL_LIST
    :T: TOOL_COMMENT><EOL>
    Right now the output is like this
    (1/2 EM CRB 2FL 1 LOC)
    (1/4 EM CRB 4FL .9 LOC)
    O0001
    N300 (1/2 EM CRB 2FL 1 LOC)
    T3M6
    should be like this
    O0001
    (T1 1/2 EM CRB 2FL 1 LOC)
    (T2 1/4 EM CRB 4FL .9 LOC)
    N100(1/2 EM CRB 2FL 1 LOC)
    T1M6
    So where do I place the "GETTOOLS" to do this?
    George
    Feb 2010
    69
    Re: edit the post to move the tool list after the program number
    In your calc_start_of_tape section you will find
    :C: CALL(START_OF_TAPE)
    put your command right after
    I assume your N100 line is part of your INIT_TOOL_CHANGE_MILL section
    Oct 2009
    10
    I've tried that but it just puts the list after the :SECTION=INIT_TOOL_CHANGE_MILL
    I've tried about every location I can and still can't get the right result.
    I can't get it to move to just after the :SECTION=START_OF_TAPE
    thanks
    Feb 2010
    69
    Attach your .src and .lib file and I will take a look
    Oct 2009
    10
    I get an invalid file message when I try to upload the files. Any tricks to upload files?
    Feb 2010
    69
    try changing the extensions to .txt
    Oct 2009
    10
    Feb 2010
    69
    the .lib file I expected was FANCMD.lib , not MILL.lib
    Do you make your changes in the MILL.lib file?
    If so, do them in the FANCMD.lib and recompile, it should work!
    Its better not modifying the mill.lib file, everytime you want to do changes, copy the section you want to modify in (yourpostname).lib and do the mods, it will override the mill.lib same section
    Oct 2009
    10
    I still have the unchanged mill.lib file. I have a fancmd.lib which is the same as the mill.lib I attached. I renamed it to try to get it to work.
    I'll try it again with the Fancmd.lib file.
    Oct 2009
    10
    I used an older lib file and adjusted it and got it to work, thanks for the help.
  1. Replies: 3
    Last Post: 01-15-2016, 07:18 PM
  2. tool list at top of v9 lathe program
    By averylooper in forum Post Processors for MC
    Last Post: 05-14-2013, 04:09 PM
  3. I want to Post a tool list to my program.
    By tmcallister74 in forum Surfcam
    Last Post: 01-14-2012, 01:31 AM
  4. outputting program number to NCI maybe a post issue??
    By Avsfan135 in forum Post Processors for MC
    Last Post: 11-24-2011, 12:18 AM
