586,700 active members*
2,779 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 32i, MDI won't clear after cycle finished
Results 1 to 5 of 5
    Jun 2008
    113
    On 18i, MDI program is automatically cleared once finished. How do I make it so that on 32i the behavior is similar?
    Thank you.
    Feb 2006
    1792
    Re: Fanuc 32i, MDI won't clear after cycle finished
    3204#6 = 0 would clear MDI program after execution.
    Jun 2008
    113
    Nice On 18i I'm used to typing several lines of code in MDI and then cycle start would run all those lines entered. However, on 32i it will only execute the last block, unless I move the cursor to the beginning. Would you know if this is achievable as well?
    Feb 2006
    1792
    Not sure, but try this:
    Set 3204#6 = 1 and 3203#7 = 0, and insert M30 as the last line of the MDI program.
    Also ensure that 3404#4 = 0.
    Jun 2008
    113
    Thank you, although I didn't chance the MDI behavior because the operators are used to using it this way.
  1. FANUC 15M Memory all clear
    By david_chen in forum Fanuc
    Last Post: 12-16-2013, 03:09 PM
  2. Clear all memory of Fanuc 10MA
    Last Post: 07-11-2012, 09:22 AM
  3. Fanuc 16i-M Can't clear Error code 5013
    By item535 in forum Fanuc
    Last Post: 04-11-2011, 11:32 AM
  4. Fanuc 0M command to clear the spindle??
    By Otterpaw in forum Fanuc
    Last Post: 04-01-2011, 06:10 AM
  5. FANUC MEMORY CLEAR & PRECAUTIONS
    By CHANDRU in forum Fanuc
    Last Post: 05-12-2009, 06:16 PM
