586,106 active members*
3,072 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > enshu yuasa accu-mill am1547 tool offsets?
    Nov 2006
    6
    can anyone tell me how to enter tool and work offsets on this machine the operators manual doesnt mention anything. It doesnt have a tool changer but I would like to set up multiple tools. It has a fanuc system 3m control.
    Thank you --Kevin--
    I just got a machine that sounds like its pretty much the same except with a nonworking toolchanger. The tool offsets look like they can be set just by hitting the offset key to key the screen and key in the data. Did you find how to set the work offset? That's the part I'm hanging up on.
    Nate
    Yuasa 1547
    Quote Originally Posted by kustomkb View Post
    Thank you --Kevin--
    Hi Kevin,
    I have the same machine. I am trying to get it up and running....can you point me in a dirrection as to what software to use with the machine? I'm sorry that I can't answer your question at this point.
    I am also getting a driver shutdown code. Where would I look for help with that? Thank you and good luck.
    Ed
    Aug 2020
    14
    Re: enshu yuasa accu-mill am1547 tool offsets?
    I have similar problem, a “not ready” alarm that won’t go away.
    See details and help please.
    https://www.cnczone.com/forums/fanuc...tem-ready.html
  1. NEED ADVICE re: Enshu Yuasa AccuMill 1547 with Fanuc 3M
    By crobox in forum Knee Vertical Mills
    Last Post: 01-20-2023, 10:00 PM
  2. Enshu Yuasa AccuMill 1547 with Fanuc 3M
    By fixer2 in forum Knee Vertical Mills
    Last Post: 08-28-2020, 12:37 PM
  3. HELP Enshu Yuasa AccuMill 1547 with Fanuc 3M
    By EDL at AU in forum Knee Vertical Mills
    Last Post: 08-28-2020, 12:31 PM
  4. How do I set up part zero and tool offsets on a CNC mill?
    By AccuMillGuy in forum Uncategorised MetalWorking Machines
    Last Post: 04-22-2009, 12:47 AM
  5. Troubles with YUASA ACCU-MILL AM 1547
    By thucmie in forum Uncategorised MetalWorking Machines
    Last Post: 09-09-2008, 08:37 AM
