586,058 active members*
4,549 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > RFQ Laser cut or Water Jet QTY12 plastic plate 1/8 - 1/4 thick (approx 12.5x12.5")
    Aug 2006
    27
    Looking to have this DXF file cut to size see attached DXF. Its approx 12.5X12.5". Needs to be cut from 1/8 to 1/4 smooth plastic (coroplast or similar). Need qty 12 for a sign blank.
    Please text quotes to
    385-233-1090
    Attached Files Attached Files
    Re: RFQ Laser cut or Water Jet QTY12 plastic plate 1/8 - 1/4 thick (approx 12.5x12.5
    The price has been PM, and if you have any questions, please contact me, [email protected]
    Cheers!
    Over 30 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding www.plusminusthree.com Email:[email protected]
    Aug 2006
    27
    The RFQ is now closed and was rewarded to P3d Creations. Thanks for everyone's quotes.
  1. 1/4" to 10 mm thick steel plate
    By kdoney in forum RFQ (Request for Quote)
    Last Post: 12-15-2011, 07:35 PM
  2. RFQ - Aluminum 0.090" thick fins, Water or Laser cut
    By jhuebbe in forum RFQ (Request for Quote)
    Last Post: 05-14-2011, 07:51 PM
  3. Replies: 1
    Last Post: 01-14-2011, 04:43 AM
  4. Cold-rolled steel plate, 13"x24", 1/2" thick.
    By Odin in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:00 AM
  5. Simple 1/4" thick 6061 plate
    By Aaron92SE in forum Employment Opportunity
    Last Post: 05-16-2008, 10:47 PM
