587,129 active members*
3,293 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > G76 internal thread clarification - 0i TB
    Jan 2008
    8
    Two line format
    New to lathes
    Got an external thread working fine, took a bit of playing but also got an internal going OK.
    Want to clarify in more detail what it is the controller is doing. As I understand it:
    G0 X22 Z5
    G76 P001060 Q50 R.02
    G76 X18.2 Z-20 R0 P900 Q500 F1.5
    This will give me a 20 OD external thread retracting out to 22 on each pass
    G0 X16 Z5
    This will give me an 18.2 OD internal thread retracting inward to 16 on each pass
    By changing the initial G0 position the controller decides internal or external? At what point does the controller decide which add each cut and which way to retract the tool? I'm presuming it's whether the initial G0 X is above or below the thread range in this case 18.2 to 20, what if the initial G0 is within that range?
    (BTW this is on a flatbed so the tool is forward of the axis, but I don't think that makes a difference?)
    Cheers, Sean
    Feb 2006
    1792
    Re: G76 internal thread clarification - 0i TB
    Initial X level with respect to the G76-second block X determines internal/external threads.
    For more details, read the Operator's Manual or this book.
    Sep 2012
    4
    Quote Originally Posted by cdspk View Post
    Two line format
    New to lathes
    G0 X22 Z5
    G0 X16 Z5
    Cheers, Sean
    Hi Sean,
    You asked: 'what if the initial G0 is within that range?'
    The internal thread is cut from Dia. 16.4 to 18.2 (= 2 * P900), The outer thread from 18.2 to 20, so far so good.
    Now, if you get into the area where the thread is cut, either you get an alarm (usual), or if the control
    accept it, it takes either the lower or higher part first (which is closest) and run the threadcycle.
    However, what will happen is that by the rectraction to Z+, the tool will retract to the starting point,
    via your starting X, dragging material with it on the way out. Your tools will not like it.
    So, avoid go in between starting and finnishing diameters. We all like some good clearance in this world
    Cheers,
    Mikie
  1. Help : Wrong Thread is cutting for Internal Metric Thread
    By dolarpond in forum G-Code Programing
    Last Post: 06-02-2017, 04:51 PM
  2. Help : Wrong Thread is cutting for Internal Metric Thread
    By dolarpond in forum Chinese Machines
    Last Post: 06-02-2017, 08:01 AM
  3. Thread milling a 1/8-27 npt internal thread
    By Slick27 in forum BobCad-Cam
    Last Post: 02-17-2016, 07:58 AM
  4. 1/4 npt internal thread
    By richcash in forum Material Machining Solutions
    Last Post: 10-20-2011, 11:34 PM
  5. Internal Thread Grinders
    By Zumba in forum Uncategorised MetalWorking Machines
    Last Post: 03-03-2007, 03:28 PM
