603,899 active members*
3,293 visitors online*
    Sep 2014
    10
    Fanuc OT soft limit 3
    Have a leadwell ltc 15 with fanuc OT. I got the machine with no parameters. Bought the parameters and have been adapting them to my specific machine. It's operational now and running programs but a random error keeps popping up.
    its "1003 soft limit 3" . It occurs in different places in the machines envelope, searched through the parameter and maintenance manual and can't find any info on it, think it's an external alarm because it's greater than alarm 999
    the video shows the alarm occurring, it's just a loop program in rapid. Took a few tries to get the alarm to show up but it stops any program dead in its tracks. It will also happen sometimes if it's being jogged around.
    soft limits work perfect and stop it before it hits any hard limits (approx 5mm between soft and hard)
    booting up with can+p hasn't stopped the alarm occurring
    thanks for any help
    https://m.youtube.com/watch?feature=...&v=l25UOLSyfpM
    Re: Fanuc OT soft limit 3
    The ladder is posting this alarm that is why you don't find it in the Fanuc books. I am betting that a setting in diagnostic is set to use this feature. Did you by chance get those with your parameters? The Diagnostic file are what the ladder uses for timers, counters, Keep Relays, and general data usage.
    Sep 2014
    10
    Yes, diagnostic file came with the parameters. I'll double check the entries.
    Sep 2014
    10
    i have found a temporary solution to this, i switched off "External Message Input" in parameter 909 bit 6
    if i find an actual solution i will post it back here.
    thanks
  1. Replies: 1
    Last Post: 02-06-2014, 07:14 PM
  2. Replies: 6
    Last Post: 06-17-2013, 04:51 AM
  3. soft limit alarm
    By bigbobr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-02-2012, 04:55 PM
  4. Fanuc 11T Soft limit troubles on Slant-1
    By shupej in forum Fanuc
    Last Post: 09-26-2007, 10:30 PM
