Originally Posted by
wolfdagon
I found a 48V power supply for about $40 but it is only 2 amps. Is it possible to modify it to give 8-10 amps? If so, how hard/expensive would it be? Could I make an easy change which would sacrifice some voltage for more amps? If I could get it to 40-42V and 8-10 amps that would be great.
I read something on the xylotek page a long time ago. If I remember it right their claim was even though your motors may be rated for 5A, 3 motors may work fine on considerably less (i.e. you don't need anywhere near 15A for the system). I don't know if that argument is specific to something in the chipset they use or if that can be made as a general argument.
Now if you have 4 of those 24VDC power supplies... then your in business.
If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
Steven
