586,077 active members*
3,968 visitors online*
    Jul 2017
    Unexpected Results
    I am working on a carve that I thought should be fairly straight forward, but for some reason am not getting quite what I expected. Here’s a picture of the model, using MeshCam to generate the toolpath. And also a picture of what was carved. Ultimately it will result in the correct final product, but seems like it is working harder than it needs to. It makes two rings in the hole, one is the outer that will be the correct final product. I’m confused by the inner ring though. It seems like this is making a nicely finished inner piece, but that piece is actually just scrap, I only care about the hole. Is there maybe a setting that can get rid of that? Or an explanation as to why it happens? Seems like the overall carve should not take as long if it’s not making that inner ring. Any advice would be appreciated! Thanks!
    Dec 2006
    177
    Re: Unexpected Results
    Upon first look, it looks like there is a ghost element that has an associated tool path. Or, you have some offset to your tool path?
    Good Luck
  1. unexpected plunge
    By benjaminellison in forum LinuxCNC (formerly EMC2)
    Last Post: 06-12-2016, 06:48 AM
  2. Unexpected behavior from Mach3
    By kievari in forum Mach Software (ArtSoft software)
    Last Post: 11-21-2013, 03:26 PM
  3. V23 sweep funtion, unexpected results
    By vetsen in forum BobCad-Cam
    Last Post: 09-16-2012, 01:23 AM
  4. unexpected error
    By forrey45 in forum Uncategorised CAD Discussion
    Last Post: 02-14-2012, 03:34 AM
  5. Unexpected Lathe; much confision!
    By serriadh in forum Mini Lathe
    Last Post: 06-16-2009, 03:29 PM
